Will those Wheels Fit an IS250 AWD - Part Uno
Old 08-23-10, 12:03 PM
netsrac
netsrac's Avatar
Originally Posted by mikez
He bought it from me, cost him his *****
So this is a See-Through Hood?
Was not sure if it was fancy paint job or photo-shop
Old 08-23-10, 12:33 PM
mikez
mikez's Avatar
HAHA
It's photoshopped, you take 2 pictures on a tripod, one with the hood down and one with it up and you layer them on top of each other. Then you get rid of everything in the hood up picture cept the engine bay.
Old 08-23-10, 01:34 PM
Wierdazndu
Wierdazndu's Avatar
HAHAHAHAHAHAHAHAHA..... that photoshop fools alot of people
Old 08-23-10, 01:58 PM
netsrac
netsrac's Avatar
HAHA
Well I thought it was photoshopped, but did not want to look stupid saying is wasn't.
Guess that did not work....
Old 08-23-10, 04:43 PM
Mv350
Mv350's Avatar
i love those engine bay shots
Old 08-24-10, 10:39 AM
LiCelsior
Retired
LiCelsior's Avatar
damn i heard those see through hoods add like +30hp...something well needed on the puny 250s.
Old 08-24-10, 01:12 PM
Joyride250
Joyride250's Avatar
i'm running F 19x8.5+35 235/35/19 and R 19x10 +45 265/30/19, my car vibrates when rolling around 20-40km then smooths out till 120km . i'm only feeling the vibrate coming from the front. I also had an alignment done after the wheels were installed and i still feel the front shake still. Do i need to change to a different tire setup to fix this? thanks
Old 08-24-10, 01:16 PM
laobo979
laobo979's Avatar
make sure they balanced the wheel correct and make sure your hub bore on the 19 are 60.1 if not you need hub rings.
Old 08-25-10, 08:49 PM
Phillee
Phillee's Avatar
I have a IS250 AWD and I wanted to put the vossen vvs-086. I was told at a shop that 20x9 in the front and 20x10.5 in the rear is possible for my AWD IS250. The tires to run that is 245-30-20 in the front, and 285-25-20 in the rear.
With some magical tire calculation this guy gave me at a shop said, "there would be 25.78 in the front, and 25.61 in the rear, leaving .17 different." ??? I don't understand?
So can i run this staggered setup with out messing up my car. I heard other wise.
It would be awesome if I could stager with these rims I want!!!!!!
Attached Thumbnails Will those Wheels Fit an IS250 AWD - Part Uno-vvs-086-wheels-.jpg   Will those Wheels Fit an IS250 AWD - Part Uno-vvs-086-rim1.jpg   Will those Wheels Fit an IS250 AWD - Part Uno-vvs-086-rim2.jpg
Old 08-25-10, 09:21 PM
PaPaHoFF
PaPaHoFF's Avatar
Yea fronts need hubrings. Will fix the vibrations
Old 08-26-10, 07:30 AM
laobo979
laobo979's Avatar
Phillie you can run stagger wheel it's just all about the tire diameter the AWD system is a 30f/70r Which allows you some room to play with different tire size. Ask papahoff he running stagger 20's no issues
Old 08-26-10, 02:05 PM
netsrac
netsrac's Avatar
OK I was wondering if I can go with 18" rims
F - 235/45-18
R - 265/40-18
Reason being is we have pretty bad roads up here (Montreal), so going with a staggered and running 35's in the rear, it is only a matter of time before I damage a rim.
I know my speedo will be off, but other than that is there any other problems?
The OD is just 0.02" difference between front and rear.
Thanks
Old 08-26-10, 03:59 PM
Salty250
Salty250's Avatar
will these fit? 19x8.5 Front +38, 19x10 Rear +43 5x114.3
http://www.lineacorse.com/wheels_lemans.html ????
Old 08-26-10, 05:25 PM
laobo979
laobo979's Avatar
Salty250 it not the rim you gotta worry about it the tire size cause the rims will fit you can run a 225/35 or 235/35 front and rear 265/30 and 275/30
Old 08-26-10, 06:01 PM
Phillee
Phillee's Avatar
what does 30f/70r mean?
for the vossen vvs-086 20x9 front and 20x10.5 rear with tire size 245-30-20 and 285-25-20. I was told there is a .17 difference in diameter. Will that hurt my IS250 AWD?
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
