Lexus is 220d
Old 04-01-11, 02:26 PM
DreamerzCC
DreamerzCC's Avatar
Choose between two groundbreaking diesel engines. The new IS 200d has very good fuel economy of 5.1 l/100km and emits just 134 g/km of CO2. Yet it produces 110 kW of power and 340 Nm of torque to deliver responsive performance.
The IS 220d is more powerful (130 kW / 400 Nm) for quicker acceleration and a higher top speed. But it still achieves 5.5 l/100 km and only emits 144 g/km of CO2.
Both models set new standards for refined clean diesel performance. The IS 200d is more fuel economic and the IS 220d has better acceleration.
Old 04-01-11, 02:29 PM
DreamerzCC
DreamerzCC's Avatar
Model Lexus IS 220d
Engine type 2231cc, four cylinders
Power/Torque 175bhp @ 3600rpm / 295 lb ft @ 2000rpm
Transmission Six-speed manual
Fuel/CO2 44.8mpg (combined cycle) / 168g/km
Performance 0-62mph: 8.9 sec / Top speed: 134mph
Price About £22,400
Verdict A good effort spoilt by an unsuitable engine
Rating 3/5
Old 05-08-12, 12:47 AM
anelka
anelka's Avatar
2007 Lexus IS220d Sport
I bought this car in november 2011. It's not powerful enough for me. I also have a 2007 VW Passat 2.0TFSI+intake+exhaust+remmaping=255HP. and the lexus has only 175...it's so damn slow.
Decided to see what performance upgrades can be done. and guess what? NONE) there's little information on the internet, no experience of dealing with diesel lexuses in my country.
So I started by replacing the stock exhaust.
here's a photo made when i changed oil in the rear diff. you can clearly see the stock exhaust.
as you can see, on the right side a new hole appeared! it's for the second muffler
second step was getting a K&N HighFlow Air Filter
to install it, had to remove the plastic engine cover
there was plenty of sand in the airbox so i had to clean it all.
stock air filter
stock vs K&N
washed the engine cover
clean like new
yesterday, I had the cats removed
overall, the car is now faster. i can't say that it's a rocket, but the improvement is evident.
next week i'm planing to install a tuning-box because you can't do a normal remmaping.
some more photos
some more photos
Old 05-08-12, 06:54 AM
Vroomin350
Vroomin350's Avatar
nice work looking forward to your progress.
That engine bay is so much different.
Old 05-08-12, 10:28 AM
Hoovey689
Forum Moderator
Hoovey689's Avatar
Shame there's no tune available. That diesel would pump out the torque!
Old 05-08-12, 02:20 PM
detech
detech's Avatar
I also own a 220d.
There is a good way to tune the engine and thats by installing a unichip.
I already went to the distributor of Europe and he told me I could expect something like
220+ hp.
My brother's mr spyder got an increase of 43bhp with intake header exhaust and the unichip, dyno proven.
Suspension is almost the same as the IS250. I have BC coilovers for the IS250 and the fit fine.
Old 05-10-12, 06:09 PM
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
looks good, IS220D ftw
Old 05-10-12, 06:17 PM
Hoovey689
Forum Moderator
Hoovey689's Avatar
Originally Posted by detech
I also own a 220d.
220+ hp.
I'll hold judgment until I see actual results, but there are currently no chips that are able to yield results on a 2IS. You'll find the ECU cannot be tuned
Old 05-12-12, 04:39 AM
detech
detech's Avatar
They told me that the unichip would work fine on our 220d. On the dutch forum there are also members that have managed to get 207 bhp from a box called VENTURA.
http://www.venturatuning.nl/referent...xus-tuning.htm
The downside of this box is that it's plug and play, so they don't put it on the dyno and finetune it for your specific car. In that case the Unichip is much better.
Old 05-12-12, 09:51 AM
Hoovey689
Forum Moderator
Hoovey689's Avatar
saying and actually doing are two things. The "Ventura" is plug and play but they didn't put it on a dyno? Doesn't make any sense, and doesn't show anything other than numbers can be pulled out of a hat. i.e. the 207bhp. If they don't dyno there is no proof that there were any gains. 207 means nothing really. You can't blame me for being skeptical. Not saying it can't be done, but someone would have to invest a lot of time and money into breaking the ECU, which frankly for the aftermarket of more modern Lexus's isn't that lucrative.
do you have a link to the thread in the Dutch Forum?
Old 05-12-12, 12:33 PM
Kurtz
Kurtz's Avatar
The unichip is not reprogramming the lexus ECU, it's a piggyback computer.
Those already exist for the ISx50 (MAPECU3, HKS FCON, etc). They're expensive, and without adding a supercharger of little benefit (about 10 hp).
But the car we're discussing isn't an ISx50... it's a turbo diesel. completely different engine, and it wouldn't surprise me at all if a piggyback could provide reasonable gains.
Old 05-12-12, 02:07 PM
Hoovey689
Forum Moderator
Hoovey689's Avatar
Angry
Even though it's a different engine, I'd assume the engine management uses very similar tuning no?
Old 05-12-12, 02:38 PM
Kurtz
Kurtz's Avatar
Not even remotely.
A diesel engine doesn't operate anything like a gasoline engine.
There's no throttle plate, no spark plugs, vastly higher compression ratios... it's a totally different thing from a gasoline motor in many ways.
Old 05-13-12, 01:54 AM
detech
detech's Avatar
I assume they tested the box the first couple of times during developping, but if you are getting it installed they don't put it on the dyno anymore.
There was a belgian member who got the same piggyback but from the belgian distributor and they did put it on the dyno and he got an increase of 30bhp.
But still I think that the unichip would be better because they can finetune it to your specific car.
And there are lots more functions to mess with.
Here's the link, but beware, it's in dutch:
http://www.lexusforum.nl/forum/viewtopic.php?f=29&t=366
Old 01-07-13, 12:50 PM
Alvo03
Alvo03's Avatar
I own 2007 Lexus IS220D
I got an exhaust from an IS250 so it doesnt look diesel
Uploaded with ImageShack.us
Quick Reply: Lexus is 220d
