HID vs halogen, afs vs non-afs, headlamp housing
dont mean to hijack your thread but are there any aftermarket headlight housing for the IS that have hid projectors at a reasonable cost? I have the halogen projects with my aftermarket hid kit but would prefer some hid projectors and im too lazy to do any retrofit.
Im not really comprehending this... I was on sewell looking at headlights and this caused me to search for an answer.... how do you know which head lights you actually have without taking everything apart?
They work...
Today, I removed the ridiculously expensive (to replace) AFS HID headlamps on my 2007 IS250 and replaced them with a set of used aftermarket Halogen headlight assemblies I picked up on Craig's List for $200. Upon removal, I inspected both types of headlamp assemblies side by side to see if I was going to encounter any issues. Aside from the lack of ballast, motors and wiring related to the AFS movement and HID functions, they appeared identical. Once installed, I turned them on and the halogen lights worked perfectly. The only side-effect was a flashing ASF Off light on the lower left hand side of the instrument cluster. I figure I can probably remove the cluster and disconnect the bulb for the annoying flashing warning lamp.
I'll likely swap in some in a few weeks once I have some extra $.
Though this was worth posting for those in the same finical perdiciment as I was.
Easy, call any Lexus dealer and ask the parts counter to run your VIN and give you a price for replacement bulbs. If they are stupidly over-priced, they are HID.
If I were to buy some new headlight housings would I be able to bolt up all the "guts" from my AFS headlights? My one headlight housing works perfectly but I cannot for the life of me find the crack or seam allowing water in. I planned on buying a new AFS housing but it's too darn expensive. My drivers housing looks new without a scract, chip, or haze so a used one to match is going to be hard to find.
Given that, I would like to buy new housings on ebay and swap over all my good parts from my housings. Can anyone confirm if this is possible?
I'll likely swap in some LED replacement bulbs in a few weeks once I have some extra $.
HID AFS stock headlights and itll work? For aftermarket conversion?
codenko
05-08-16 03:55 PM
