Seafoam?
#47
NOT TRUE. I hydrolocked 1998 Civic. You can spray water mist with sprayer if you are careful. The risk is hydrolocking the engine. Not worth it. You are damaging the piston. You could hydrlock with seafoam but that hasn't happened in my case. You can't compress water. You can compress oil, however. Luckily, nothing happened to the civic engine. I let it sit overnight and let water drain into oil pan. I changed oil the next day.
#48
Whaaaaa??? ^^^ Too much of anything is a bad thing. And oil in sufficient quantity will also hydrolock an engine as it does not compress.
Bottom line is years of accumulation can not be undone in one tank of gas or can of gue.
That said there is this product made just for top end cleaning.
https://www.westmarine.com/buy/yamal...itive--2280683
Ring-Free Fuel Additive
Clear engine deposits with a concentrated cleaner.
Take back the power and efficiency lost by carbon and varnish deposits caused by pour fuel quality. You can’t always count on getting the best fuel, Ring-Free is the solution. Yamalube Ring-Free is a highly concentrated fuel additive that removes carbon build-up from injectors, carburetors, intake valve, intake ports and combustion chambers. Formulated to combat corrosive element of the added sulfur in Ethanol blended fuels to keep fuel system electronic components and fittings in top shape. Ring-Free is designed to be used continuously and can be used with Yamalube Fuel Stabilizer and Conditioner PLUS without harmful effects. Keep your engine running smoothly even when your fuel source isn’t top quality by using Yamalube Ring-Free fuel additive.
Key Features
Concentrated engine cleaner that clears deposits, prevents varnish and carbon build upImproves power and efficiency in two and four-stroke engines
Effectively cleans fuel injectors, carburetors, intake valves, intake ports and combustion chambers
Combats corrosive element of added sulfur in Ethanol blended fuels
Compatible with use of Yamalube fuel stabilizer and conditioner PLUS
Formulated for continuous use.1 oz. treats 10 gallons of fuel
Key Features
#49
My coworker showed me his damaged valve removed from his engine. He hydrolocked it with seafoam. What product is it for top cleaning?
#50
I use Seafoam on my gas tank only.
#51
That said this doesn't add up. You don't bend valves from hydrolock. You bend the rod, crack pistons, damage the crank and/or block.
Follow the link; yamaha ring free is the product. It works well so I'm told. Never used it personally. It's a tad spendy but few complaints for not being effective. Again; dont OD...
lexuspleus
RX - 3rd Gen (2010-2015)
06-27-19 08:53 PM
