Wheel Spacers with Fsport Springs?
Old 03-30-10, 10:19 AM
mikez
mikez's Avatar
Originally Posted by niteLEX
hey mikez...what brand spacers did you use? Im leanin toward Ischiba but I'm unsure on V1 or V2? What do you reccomend?
I bought it from a friend who had a shop custom fabricate one with the built in studs. Drove on it for 30k miles with no issues then I sold it. To be honest it makes no difference for V1 or V2 if the studs are provided by the same brand. But for long term driving I would say the ones with the extended studs... but if the studs are made correctly then it really doesn't matter. Just make sure you have the right size hub rings with your wheels.
18x8 +40m on 225/40/18 (factory recommend?) all around with spacer in the back... lowered on F sport springs
Old 03-30-10, 11:28 AM
iRock
iRock's Avatar
^ u should get some gold emblems.
Old 03-30-10, 12:33 PM
blk250
blk250's Avatar
nice rims!
Old 01-23-15, 02:55 PM
STARBWOY
STARBWOY's Avatar
Did you get longer studs .......I got 10mm spacers and original studs are too short
Old 05-08-21, 11:25 PM
Azoy
Azoy's Avatar
Default 2013 is350c f sport. Put in spacers and need advice
1st time posting here, sorry if this the wrong place to ask.
So i have a 2013 IS350c F sport. And i installed 1 inch spacers all around. Wondering if i need to take them back off or what. I have 255/40 ZR 18 tires in the back and 225/40 ZR 18 in the front. I am not rubbing in the front
anywhere on turns agressive driving and all. And the handling is amazing. But i notices speed bumbs/pot holes. Or just anything that makes back end bounce alittle and it rubs fender to tire. Do i put a little spacer in the suspension to lift it alittle ao it doesnt rub. Or .... this is where i need ideas. After market rims (kong) if that matters.
Old 05-09-21, 10:24 AM
primavera
primavera's Avatar
Looks like you have a bit too much spacer on the back. Try 20 or 15mm instead. That should give you extra clearance and will prevent from rubbing on dips.
Easiest way to find out the thickness is by stacking up washers.
neilvosko
Suspension and Brakes
365
11-13-23 12:24 PM
Ciggy
17
03-23-20 12:59 PM
KNIGHTX50
10-03-16 11:23 AM
ISF-88
01-22-11 06:21 PM
josephx66
10-18-10 03:45 PM
Quick Reply: Wheel Spacers with Fsport Springs?
