Will those wheels fit? START HERE.
Old 09-05-09, 10:45 AM
  #661
ChrISF
ChrISF's Avatar
just mount your rear wheels to the front and test them out LOL
youll be fine with the correct offset...like no less than +25
Old 09-05-09, 10:48 AM
  #662
mdgrwl
mdgrwl's Avatar
yeah, i guess I could do that but its a big o'l 245 tire on the rear 9.5's... that may not give the most accurate "will I rub or not rub" reading...
more comments if possible... i'll see about putting the rears up front... should be interesting.
Old 09-05-09, 11:29 AM
  #663
ohiois350
ohiois350's Avatar
I wonder the same too, I am going to test my rear wheel to fit the front, right now my rear is 20x9.5 +35offset and running 255-30-20, I will test to see if there is any rubbing to the fender? I know it hit the plastic inner fender, which I already push it back, all I hope it'll not rub the fender. And are there anyone running 20x10.5 with +40 or 45 offset without any issue? because I still have my 285-30 tires left to put on the new wheels
Old 09-05-09, 11:57 AM
  #664
ISBU
ISBU's Avatar
my front wheels are 9.5 wide, no rubbing issues but i'm running 225 tires. with the right offsets and tires you should be fine.
Old 09-05-09, 12:00 PM
  #665
areukhmer
areukhmer's Avatar
If u wanna test fit your rear 9.5 wheel to the front dont you have to consider the fact that the rear wheel disk might not clear the front calipers esp the IS350?
Old 09-05-09, 12:01 PM
  #666
passnu2
passnu2's Avatar
just go 19x10 front and 19x11 in the rear
Old 09-05-09, 04:43 PM
  #667
Noz
Noz's Avatar
I'm running 9.5 +35 up front with 235 tires. My liners are pretty much destroyed, but who cares right.
Old 09-05-09, 05:05 PM
  #668
hmsis250
hmsis250's Avatar
just get some black duct tape and know wold know the difference. hahaha!
Old 09-05-09, 08:19 PM
  #669
Calviin
Calviin's Avatar
offsets offsets offsets.
Old 09-05-09, 11:30 PM
  #670
ohiois350
ohiois350's Avatar
My setup is going the same with your, but the tire would be 245- 30, is it still too wide? and where did your liner got damage? is it hit when it turn or it go over the speed bump?
Old 09-05-09, 11:48 PM
  #671
dangy
dangy's Avatar
Im running 9.5+28. Rubbing and loving it.
Old 09-06-09, 01:19 AM
  #672
love67
love67's Avatar
mm...what about 18x9+25? with 225 or 235 tires? how bad?
Old 09-06-09, 09:39 AM
  #673
mdgrwl
mdgrwl's Avatar
So I take it from comments that a 9.5 is just fine, as long as the offsets and tire choice are correct.
Right now, I'm running a 19x8.5 +23 with a 225 tire. (I'm not rubbing whatsoever after extensive front fender mods). So my question is what tire/offset combo in a 9.5 would best emulate what I'm running in terms of equal flushness & similar tire stretch?
I'm guessing 19x9.5 +35 or +36 with a 235 tire? That kinda equates to what I'm running above? This would give the same flushness and same sorta tire stretch correct?
Old 09-06-09, 09:48 AM
  #674
dangy
dangy's Avatar
I think a 19X9.5+35 with a 235 will be fine. Maybe some minor rubbing but nothing to worry about. My set of wheels is gonna be 19x9.5+20 up front. Just wait
Old 09-06-09, 10:07 AM
  #675
mdgrwl
mdgrwl's Avatar
why do you think I would rub if I'm not rubbing now? (again, extensive fender mods done)
- this should match my same flusheness... and a 235 tire on a 9.5 should match a similar stretch that I'm running... what part do you think would rub? if your talking about the fender liner, I aready heated the entire wheel well so far away from the wheel its crazy, its like I don't even have a fender liner (hence I'm not rubbing) - but if you think i would still rub, what part would rub?
Quick Reply: Will those wheels fit? START HERE.
