Will those wheels fit? START HERE.
Old 06-06-12, 09:45 PM
  #3571
projectdna
projectdna's Avatar
try adding a spacer and then see if the roller can make a full pass.
Old 06-07-12, 01:59 AM
  #3572
nitsua
nitsua's Avatar
Looking to pickup a set of Linea Corse Dynas from Wheeldude, 19x8.5/10 (e30F/e38R). Tires will be 235/35/19 265/30/19. Going to be dropped on H&R springs. My question is, will I rub? And what spacers would I need to run to make it look flush without having to do any fender mods. Thanks
Old 06-07-12, 05:04 AM
  #3573
JayDMiS
JayDMiS's Avatar
What tire size would you suggest on Varrstoen 18x9.5 and 18x10.5 +22. I'm on BC coilovers and your help is greatly appreciated. My fenders are rolled and the front tab has been relocated.
Old 06-07-12, 09:21 AM
  #3574
projectdna
projectdna's Avatar
can't tell you what you need to do to make them work since you didn't supply offset information.
225/40-18 + 245/40-18.
Old 06-07-12, 11:31 AM
  #3575
Hilary
Hilary's Avatar
Anybody have a picture of an IS350 with:
20x8.5 +38 on the front
20x9.5 +38 on the back
I'm looking at the Black Art Tux Wheels.
The car is Stock.
Will they rub?
Old 06-07-12, 11:50 AM
  #3576
JayDMiS
JayDMiS's Avatar
I tried those exact same sizes and the stretch was just too much
Old 06-07-12, 12:07 PM
  #3577
projectdna
projectdna's Avatar
that's the point with those specs; you have to run stretched sizes.
if that's something you're not comfortable doing, then you shouldn't have gotten varrstoens in those sizes.
Old 06-07-12, 12:51 PM
  #3578
JayDMiS
JayDMiS's Avatar
I don't have a problem running a stretch but the tire place said they weren't sure if the tires were going to seal properly.
Old 06-07-12, 01:05 PM
  #3579
projectdna
projectdna's Avatar
225/245 on 9.5/10.5 (respectively) will work fine and is recommended.
Old 06-07-12, 01:09 PM
  #3580
aggatek
aggatek's Avatar
Thanks for all the help. I finally received my rims.
The fitment on the front are good but my rears are in question.
I went with a "Hella Flush " fitment. 19x10 +26.
Currently I have a 235/35 tire and I have a question about tires and fender rolling/pulling.
1. I plan on going to a 245/35 but was wondering will a 255/30 work with a fender roll/pull?
2. Does a fender pull make my rear fender a little more flush? [IMG][/IMG]
3. Can someone show me what a fender pull looks like exactly? I do not notice what the fender looks like with a pulled fender? Any pics would greatly help.
I hit a big dip before with two people in the back seat and the fender hit my wheel edge. Luckily it didnt crimp my fender but that is why i am looking into this now.
Old 06-07-12, 01:26 PM
  #3581
projectdna
projectdna's Avatar
2. Does a fender pull make my rear fender a little more flush? -pic snip-
1. the sidewalls may be too upright and come in contact with rolled edge on the inside of the fenders when a load is put on the rear.
2. pulling the fender out should make the wheels look less, uh, poke-y. however...
3. a good fender pull should bring the fender out but not disturb the lines and creases on the fender. if your fenders are rolled, the rolling action should have pulled the fenders slightly. but from your pic, it looks like it needs more than a light pull.
Old 06-07-12, 03:44 PM
  #3582
silk509
silk509's Avatar
will these fit Varrstoen ES 2.2.2 staggered wheels 19x9.5 Front 19x10.5 Back painted Matte Black with red pin stripe.
Hankook Evo Tires 245x35x19 Front 275x35x19 Back. off set are 11 i belivve
Old 06-07-12, 04:09 PM
  #3583
projectdna
projectdna's Avatar
1. the required fender work for your proposed specs has been covered in this thread many times already. please use the in-thread search function.
2. those tire sizes WILL NOT WORK. you will need to mount the 245's in the rear and go with 225/35-19's in the front. this is after getting your fenders worked on.
Old 06-07-12, 06:05 PM
  #3584
SJ408sgmIS
SJ408sgmIS's Avatar
I believe he said he had +30 front, +38 rear for his offset
Old 06-07-12, 06:53 PM
  #3585
nitsua
nitsua's Avatar
Good eye SJ408sgmIS, thats what I meant.
Quick Reply: Will those wheels fit? START HERE.
