Will those wheels fit? START HERE.
Old 02-25-12, 04:14 PM
  #3211
Sango
Sango's Avatar
Dont' know, I'm not a fan of tire stretching, it is not good for the tire. 255's maximum wheel spec from the manufacuter is 10" so 10.5" is already stretching.
xna,
Not sure if you got my message. I'm now thinking of going 19x8.0 front and 19x9.0 using work wheels using Lexus's offsets of 40mm. Would this still be ok?
I happen to see a worker's IS with work wheels suing the 19x8.6 and 19x9.5 wheel and the appeal of the lip sticking out futher than the tire did not seem to suit my taste.
Old 02-25-12, 05:04 PM
  #3212
projectdna
projectdna's Avatar
xna,
255 on a 10.5"-wide wheel is barely starting to stretch the tire. now 245? that's a different story.
btw, i'm sorry i wasn't able to respond to your PM earlier, but i'm glad you caught my attention. i wasn't sure what your PM meant, so your post clarifies things.
you can use 19x8/19x9 +40, but make sure your proposed specs clear the brake calipers. it's best to refer to work wheels' sizing chart to determine that.
if you're going w/ 19x8/19x9 +40 set-up and you want the widest tires possible, try 235/35-19 + 275/30-19 for the ultimate beefy tire set-up.
Old 02-26-12, 02:54 PM
  #3213
PACMAN031
PACMAN031's Avatar
19x9 +26 19x10.5 +26
Old 02-26-12, 03:42 PM
  #3214
projectdna
projectdna's Avatar
cool specs, bro.
/sarcasm
now, what would you like to know?
Old 02-26-12, 06:51 PM
  #3215
PACMAN031
PACMAN031's Avatar
Fender rolling or pull or both? What tires sizes should i run? Car is not lowered yet
Old 02-26-12, 07:46 PM
  #3216
Vroomin350
Vroomin350's Avatar
Originally Posted by projectdna
F-Sport wheels? yes, they'll bolt right up and clear the oem IS350 calipers.
OEM IS-F wheels? no, they'll need spacers to clear the oem IS350 calipers.
Like always, Thank you dna.
Old 02-26-12, 08:13 PM
  #3217
projectdna
projectdna's Avatar
both.
225/35-19 + 245/35-19.
shave the fender tab when you do.
Old 02-27-12, 06:05 AM
  #3218
PACMAN031
PACMAN031's Avatar
What offset would i have to go with not to have to do a pull
Old 02-27-12, 08:34 AM
  #3219
projectdna
projectdna's Avatar
depends on the width of the wheels and your desired tire set-up (stretched vs. meaty).
Old 02-27-12, 08:59 PM
  #3220
trippy
trippy's Avatar
will 19x8.5 front and 19x9.5 rear and tire size 245/35 front and 275/30 rear rub ? my front is lowered 1.3 and rear is .8 please help me out im a total noob at tires thanks ! im trying 2 avoid fender rolling
Old 02-27-12, 09:19 PM
  #3221
projectdna
projectdna's Avatar
it would help if you posted the wheels' offsets (which you didn't), but i already know you're talking about starknight's TE-37's that are in the wheels/tires classified section.
just run the same sizes he ran, since he had no problems running those tire sizes. if all else fails, go a size narrower.
Old 02-27-12, 09:21 PM
  #3222
trippy
trippy's Avatar
thank you sir
Old 02-29-12, 05:34 AM
  #3223
DnkNgs
DnkNgs's Avatar
Originally Posted by kado413
that is haaard!!
I think thats the way im gonna go..
any fender work on the fronts or just camber?
what tire size are you running?
holy ****!
Old 02-29-12, 05:35 AM
  #3224
DnkNgs
DnkNgs's Avatar
Hey guys quick question. I have a 2" drop w/ H&R springs. I bought the car with 19" MRR w/ 255/35/19 tires. I just bought some 18" w/ 245/45/18 Winter tires. I had no rubbing problems with the 19's but I was wondering if you guys knew if the 245/45/18 tires on the 18" wheels would have rubbing problems anybody run in to that?
Old 02-29-12, 09:53 AM
  #3225
projectdna
projectdna's Avatar
due to the lack of specific details that would actually help answer your question (wheel width/offset), i'm just going to give you a generic answer.
maybe.
Quick Reply: Will those wheels fit? START HERE.
