Will those wheels fit? START HERE.
Old 07-07-11, 02:03 PM
  #2281
projectdna
projectdna's Avatar
Originally Posted by HAYSTACK
20x9 F +36, and 20x10.5 R +45
Is this do-able?
do-able in terms of?...
Old 07-07-11, 02:10 PM
  #2282
HAYSTACK
HAYSTACK's Avatar
not having to roll the fenders. 225/30 F and 275/30 R? I do not have a drop as of yet.
Old 07-07-11, 03:50 PM
  #2283
CalitriSC
CalitriSC's Avatar
Originally Posted by Mv350
your offsets are completely different than a standard isx50
yea I know this. And my wheels fit fine on a regular IS 250.
Old 07-07-11, 03:58 PM
  #2284
projectdna
projectdna's Avatar
unless you're running some monster truck-sized wheels/tires combo, @ stock ride height your proposed wheels/tires set-up should be fine.
Old 07-07-11, 04:37 PM
  #2285
sick
sick's Avatar
Really? What are your offsets? I would like to run a 295 on the rear, that'll look badas$.
Old 07-07-11, 04:49 PM
  #2286
CalitriSC
CalitriSC's Avatar
I wish I knew, but D2 Forged doesn't release their offsets but I can try and find the pics for you on a regular IS.
Edit: here you go, 20x11 with 295/25/20 rear. Sits flush on IS 350
Old 07-07-11, 04:57 PM
  #2287
projectdna
projectdna's Avatar
^^ most likely high offsets in the rear - which translates into a good amount of wheel backspacing.
Old 07-07-11, 05:00 PM
  #2288
CalitriSC
CalitriSC's Avatar
yea I'm guessing in the 40s in the rear and 30s in the front.
Old 07-07-11, 05:19 PM
  #2289
Mv350
Mv350's Avatar
ahh i see, sorry to jump on ya like that. that looks extremely good. im guessing mid 40 offset in the rear.
Old 07-07-11, 05:32 PM
  #2290
CalitriSC
CalitriSC's Avatar
haha its cool, i wish i could run the low offsets in the rear like you!
Old 07-07-11, 06:52 PM
  #2291
Husni08
Husni08's Avatar
Originally Posted by Husni08
Would I need to have any fender work done if I threw some 15mm spacers on my stock rear wheels wrapped in 275/40/18? Any rubbing issues? Thinking about it as a temporary set up
Bump.
10char
Old 07-07-11, 07:32 PM
  #2292
projectdna
projectdna's Avatar
Bump.
10char
ride height/suspension mods?
Old 07-08-11, 12:34 PM
  #2293
DaKi3241
DaKi3241's Avatar
hey guys. Might pull an aggressive fitment here. I do know about rolling the rears.
As for the fronts... what are some possibilities to minimize rub, fender liner, and this metal tab/piece that scrapes off our tires?
Looking at 19x9.5 +22, 19x10.5 +22.
As for tires, would these specs be suitable?
225/35/19 and 265/30/19?
Ride height.... it will be pretty low and am willing to adjust them to have that hellaflush look.
Old 07-08-11, 01:39 PM
  #2294
Mv350
Mv350's Avatar
remove the front fender tab. roll and tiny pull the front, slight pull in the rear. and your set, those tires will work perfectly with this setup.
Old 07-08-11, 02:21 PM
  #2295
sick
sick's Avatar
Same as the above person 10.5 +22, but don't want to pull. What size tire? Or can i run 265/30 using camber arms? I going to be slightly tucking.
Quick Reply: Will those wheels fit? START HERE.
