Will those wheels fit? START HERE.
Old 11-29-10, 05:36 AM
  #1741
JMcDonald
JMcDonald's Avatar
^^^^ the man has spoken....
Old 11-29-10, 07:47 AM
  #1742
6Sp33d
6Sp33d's Avatar
Originally Posted by Mv350
yes those tires will fix it
edit: or even 215/35 235/35
thanks...why isnt this a sticky yet...?
Old 11-29-10, 07:54 AM
  #1743
JMcDonald
JMcDonald's Avatar
Um...it is... Its on top under " 2IS Wheel Thread Index "
Old 12-01-10, 01:23 AM
  #1744
kanklez
kanklez's Avatar
Anyone can tell me if this setup will work without any fender work?
18x9 +25 215/35
18x10 +25 215/35
thanks
Old 12-01-10, 04:28 AM
  #1745
JMcDonald
JMcDonald's Avatar
I would say you would most likely your going to rub a little. You might want to get the fenders rolled a tad. Theres a guy running 18x8.5 +20 and 18x9.5 +20 and he rubs very little just on turning, but he took a heatgun to his lining and fixed it I believe. I don't know what tire setup he is running.....with that being said I think a 215 would be fine BUT you might have to roll a little depending on how low you go.
Old 12-01-10, 04:54 AM
  #1746
Mv350
Mv350's Avatar
have fun mounting that rear tire. just mod your fenders.
Old 12-01-10, 05:00 AM
  #1747
JMcDonald
JMcDonald's Avatar
^^^ I learn from the best
Old 12-01-10, 10:23 AM
  #1748
djmukn
djmukn's Avatar
Default Rubb???
Im looking to purchase the Lumarai Morro Set with the following configuration,
20x8.5 with 225/30/20
20x10 with 275/30/20
or
19x8 with 235/35/19
19x9.5 with 265/35/19
or
19x8 with 235/35/19
Im looking for the least possible rub without having to make an fender adjustments. what do you guys think? i really need some help. also with the 20s, is it a big problem driving around having to worry about the roads? im also dropped with the F-Sport Springs
Old 12-01-10, 11:59 AM
  #1749
JMcDonald
JMcDonald's Avatar
All of those setups would work just fine with no rub depending on the offset.....I'm running 20x9 +38 235/30 and 20x10.5 +42 275/30 and I dont rub at all. But I beg you.....DO NOT put 19s in front and 20s in rear....looks dumb IMO.
Old 12-01-10, 02:17 PM
  #1750
hazmat
hazmat's Avatar
got a good deal with some volks
will this work?
18x8.5 +30 offset probably going 235/40/18
18x9.5 +35 offset probably going 265/40/18
Thanks in advance
Old 12-01-10, 10:12 PM
  #1751
Mv350
Mv350's Avatar
with those tires you might rub a little in the back. depends on drop.
Old 12-02-10, 12:16 AM
  #1752
djmukn
djmukn's Avatar
Default Rubb???
lol thanks for the info man, really helps alot, are you dropped? im running on the f-sport springs
Old 12-02-10, 04:16 AM
  #1753
JMcDonald
JMcDonald's Avatar
Yea Im slammed on BCR Coils
Old 12-03-10, 12:29 PM
  #1754
jsjc
jsjc's Avatar
Hi guys,
I'm looking at these TE37 with this setup. Do I need to cut/shave/roll the lining or arches ?
18x9.5 for the front (+40 offset)
18x10.5 for the rear (+45 offset)
And what tyre would best to avoid doing any mods to the lining or arches?
Thank you in advance and much appreciated.
Jason
Old 12-03-10, 07:19 PM
  #1755
350zTT
350zTT's Avatar
my nephew got some 19x9 19x10 +25 all around...he has 245/35 up front so im going to use those for the rears...what size tire should i get for the front? 225/35?
Quick Reply: Will those wheels fit? START HERE.
