is350 with isf wheels 19x8 front 19x9 rear with 15mm spacers all around ....Will this rub with stock 225-30-19 255-40-19 tires. Can i go with a up in tire size and not rub???
as long as youre willing to pull fenders... those should work
With 20's and a low off set like that what size tire would you need to run? Reason I ask is i'm looking at something very similar. I don't want to run a 30 series tire. Could you run a 35 series? Or would it need stepped to a 19" rim to fit the 35 series tire?
Holy ****, am I supposed to read all 107 pages before asking a question?
Looking at running 18x9f, 18x10r, +22 offset on my IS250 RMT.
I'm on 18x8.5 and 18x9.5 +30 right now and the only "issue" up front is rubbing the fender liner and in the back I have a small dent in the quarter (someone kicked it) that one tire rubs on, but it's coming back from the body shop so that should be fine. I'm thinking I should be able to fit the 9's and 10's +22 with just a fender roll. Is that gonna look pretty aggressive or should I push it a bit more?
its gonna be aggressive... of course anyone can ALWAYS push it a bit more... just depends on HOW aggressive you want. Its def going to be more aggressive than most.
