question about foglights!help!
Old 06-23-09, 05:52 PM
Proper 350
Proper 350's Avatar
Default question about foglights!help!
hey i just wanted to know if their is a easy way to tap into foglight wires to connect to parking light.so my fogs will be on when my parking lights are without using a separate relay.also if anyone can help me with a headlight wiring diagram/schematic for the 2IS.thanks in advance for any feedback
Old 06-26-09, 05:45 PM
Proper 350
Proper 350's Avatar
Ok. Since nobody knew how to do the fog lights mod... I went ahead and did it myself with success. So here is the DIY if you want do the mod.
The tools you need are:
1. Short philips head screwdriver
2. Wire cutter with crimp tool
3. 1 tap in squeeze connector
4. 1 female and 1 male connector
5. Lighted fuse/power tester
6. Electrical tape
7. box cutter or razor blade
8. needle nose pliers
9. 1 foot of power wire (12 -14 gauge)
Steps:
1. Take off engine covers. (front and driver side)
2. Remove driverside fuse box cover.
3. Remove screw that holds washer fluid tube for easy access.
4. Remove backcover of driverside parking/drl light.
5. Remove parking light bulb from housing.
6. At fuse box locate and cut green with red stripe wire right in the middle.
7. At fuse box locate and cut lime green with silver rings wire right in the middle.
8. From wireloom side strip both the green with red stripe and lime green with silver ring wires and crimp together into one female connector.
9. Take extra power wire and connect one end with male connector.
10. Connect male and female connectors together.
11. Locate green power wire from parking light harness.
12. Use box cutter to cut rubber sleeve for easy access to wires.
13. Connect other end of extra power wire to green power wire of parking light harness using the squeeze connector. Make sure to have good connection.
14. Turn on parking lights for test. If your connections are good then your fogs should work whenever your parking lights are on.
Note: This will render your fog light switch disabled.
Attached Thumbnails question about foglights!help!-ismodifiedfusebox.jpg   question about foglights!help!-iswires.jpg   question about foglights!help!-iswiredtoparking.jpg
Old 06-26-09, 05:50 PM
vuiskool
vuiskool's Avatar
thanks, but i dont wanna interfere with manufacture warranty.
Old 06-26-09, 05:58 PM
Proper 350
Proper 350's Avatar
The finished product. Fog lights with parking lights on
Attached Thumbnails question about foglights!help!-isfogparkingfrontupper.jpg   question about foglights!help!-isfogparkinguppercornerview.jpg   question about foglights!help!-isfogsparking.jpg
Old 06-26-09, 06:00 PM
Proper 350
Proper 350's Avatar
Will also work with highbeam
Old 06-26-09, 07:21 PM
ELL Y
ELL Y's Avatar
Proper 350,
That is very cool indeed. I would consider this primarily for the fact that it works with high beams too- Thanks for the informative writeup
Old 06-27-09, 12:24 AM
ankurman20
ankurman20's Avatar
cool mod...
Old 06-27-09, 07:05 AM
Lexasaurus
Lexasaurus's Avatar
Hmm, i sort of want to do this. I wish there was a way to just flip them on whenever you'd like without projectors on.
Old 06-27-09, 09:54 AM
Phiber
Phiber's Avatar
Very nice.
Is there any easy solution to fog lights on without headlights or city lights on?
Old 06-27-09, 10:07 AM
Proper 350
Proper 350's Avatar
with this mod the fogs are connected to parking lights so whenever parking lights are on the fogs are.1st notch fogs/parking/drls are on WITHOUT low beam projectors
Originally Posted by Phiber
Very nice.
not sure of an easy solution but i would think you would have to run fogs to a separate relay and switch..
Old 06-27-09, 10:09 AM
Phiber
Phiber's Avatar
Just wondering, why would you want parking light on with fog lights compared with fog lights on with out other lights?
Old 06-27-09, 10:53 AM
Proper 350
Proper 350's Avatar
i think it looks better that way...i dont think it looks as good with fogs on alone and i didnt want to add an extra switch
Old 06-27-09, 01:40 PM
sinister2c
sinister2c's Avatar
theres a way to do it and still have your fog switch work.
I've done it on other cars. the foglight relay used the headlight power as a signal so if you can locate this wire on the relay and reroute it to the parking light, it will allow you to operate the fog lights with the switch when the parking lights are on.
Can someone look up the wiring diagram on the Toyota Tech site
Old 06-27-09, 03:11 PM
ISFHAHA
Check your PM - SALES ISSUE
ISFHAHA's Avatar
Is there any way we can turn off the fogs any time we want ? Or it will stays on when DRL are on ?
Old 06-29-09, 08:22 PM
sinister2c
sinister2c's Avatar
This is the integrated control unit with the foglight relay. One of those wires is connected to the headlight circuit. We just need to figure out which one it is and route that wire to the parking light circuit and we can get the fog lights to come on with parking lights via the switch.
Quick Reply: question about foglights!help!
