CAn't get battery cover off
Old 12-29-09, 04:10 PM
spoofy
spoofy's Avatar
Default CAn't get battery cover off
I am replacing my battery for the first time and I'm unable to remove the battery cover. There are 2 loops on the side of the cover holding 2 wires going to the positive terminal that seem to be holding it down. Should I just be able to pull the cover off is there a way to disconnect the loops holding the wires?
Attached Thumbnails CAn't get battery cover off-2009-12-29-18.01.32.jpg   CAn't get battery cover off-2009-12-29-18.01.02.jpg
Old 12-29-09, 11:59 PM
350PsDMeuP
350PsDMeuP's Avatar
had the same problem, the clips are a pita. let me see if i can find my post.
Old 12-30-09, 12:05 AM
chris07is
chris07is's Avatar
same here...had a problem with it..i even scratch my self and had scarrr thing is BI*******..when you take that offf dont even bother to put it back coz it wont fit, unless you buy oem brand!!!
350PsDMeuP
350PsDMeuP's Avatar
found it.
https://www.clublexus.com/forums/is-...yfob-help.html
Old 01-07-10, 08:29 AM
600rr05
600rr05's Avatar
I actually have to replace my battery this week also i tried changing it at night but didn't get far as the clip stopped me haha
Old 01-07-10, 02:49 PM
nipperiley
nipperiley's Avatar
I just replaced by battery, 2006 IS250. I used a short pry bar ( a long flat blade screwdriver might work too). It took some force, but the plastic clip (female end) did detach from the metal clip (male end) which is attached to the plastic battery cover. Nothing broke in the process. You may not be able to use this plastic cover if your new battery is not the same height as the original Lexus battery.
devnull77
01-11-21 10:56 AM
cmikey
07-07-19 05:20 PM
LS430Lexus
11-10-16 06:02 PM
crombie92
08-24-11 10:17 PM
BR_blake
06-07-08 11:20 PM
Quick Reply: CAn't get battery cover off
