how to change the daylight headlight bulb
hey guys u no how during day time the headlight light is like orange yellow i want to change it to the full bright yellow is it easy to change the bulb or is it a hassle?
an advanced search of the 2is section using the keyword "DRL" would have helped you find this:
https://www.clublexus.com/forums/is-...?highlight=DRL
this same thread is also listed in the 2is FAQ and DIY thread:
https://www.clublexus.com/forums/is-...tart-here.html
if you're capable with garage tools and can follow instructions properly, you should have no problem with the bulb swap.
hope this helps.
hope this helps.
omegabyte
08-28-12 06:04 AM
