This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Thread Tools Display Modes
Old 11-07-09, 09:44 AM   #1
OlivrTwizt
Trader Score: (0)
Default Removing rear door trims/panels
I had the unfortunate experience of a child vomiting all over my rear door, and the rear seat where the seat meets the footwell (mostly on the mat, but some still on the carpet)
I'm looking for information on how I can remove the rear door panel/trims so that I may clean in between the gaps, and also make sure that my ML speakers haven't been damaged!
The worst thing is that I have the alcantara interior and I'm worried about damage to it, so I want to try and take the trim off and properly clean it, if it unhooks easy enough...
Can anyone help with pictures/photos from the manuals?
Thanks in advance
__________________
'08 1G0 IS250 Sports AUDM - ML/Navi/Alcantara/AFS/Fully Loaded
V-Leds/6000K LB/4750K HB/More to come..
OlivrTwizt is offline   Reply With Quote
Old 11-07-09, 10:08 AM   #2
nmpeter
Trader Score: (2)
nmpeter's Avatar
Send a message via AIM to nmpeter
I've never taken off the rears but I've taken off the fronts. You can probably start by taking off the covers where the lock/handle is and unscrew whatever is behind that and then take off the window switches by just gently taking it off with your hand alone or a screw driver with a towel over it. That should get you started, not sure what else there is.
nmpeter is offline   Reply With Quote
Old 11-07-09, 10:18 AM   #3
Phil888
2008 Lexus IS
Trader Score: (0)
Phil888's Avatar
Its really easy to take apart anything. You just gotta find all the hidden screws. When you acutally pull it apart you gotta pull hard enough to allow it to pop out. But make sure you find all the "HIDDEN screws" and loosen them or else you may break something. Flat head is your friend!
__________________
Phil888 is offline   Reply With Quote
Old 11-07-09, 02:08 PM   #4
2slow
Trader Score: (1)
2slow's Avatar
http://www.clublexus.com/forums/is-s...-pictures.html
Door panels.
2slow is offline   Reply With Quote
Old 11-07-09, 09:51 PM   #5
OlivrTwizt
Trader Score: (0)
Thanks guys,
Yeah I found that via searching before (My bad, I should have been a bit clearer but it was 3:30am when I posted :P) but I was more after the clip locations.. I'm a bit wary of just pulling in random locations, I'd rather find out where the clips are and gently ease them off one by one using a pry tool
__________________
Tags
400h, car, clean, door, lexus, panel, rear, remove, rx350, trims
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
