Key not detected...
Old 12-25-12, 07:05 PM
Toxicxk23
Toxicxk23's Avatar
The manual key suggestion raises a concern for me. (sorry for thread jacking) I can't lock my glove box with this key. I haven't tried the door lock yet but do you guys think this will run into the same problem as my glovebox?
Old 12-25-12, 09:17 PM
o7iS250
o7iS250's Avatar
I went to a store called "Batteries Plus" and got 4 of our batteries for $12! my car literally stopped turning on in their parking lot.. very close call
Old 12-25-12, 11:00 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Originally Posted by MIA_LEX
And if your Key fob is dead just hold the fob right to the START button and press it a few times until the car starts.
Hold it there until the light comes on. You only need to press it once
Jeff
Old 12-26-12, 10:37 AM
my1s250
my1s250's Avatar
I get mine for free at sewell lexus ......
Old 12-26-12, 01:37 PM
KillaIS250
KillaIS250's Avatar
Probably. If you can't lock the glovebox with the key, then for whatever reason you don't have the right key for your car. You can get one cut at your dealership. Or you can order one precut for your car from Sewell after verifying your car's info and your ownership (~$60 with CL discount)
Old 09-25-13, 09:21 AM
DickBeyer
DickBeyer's Avatar
The procedure for opening the car door with the key, and starting the engine by holding the fob next to the starter button, is very important. A friend of mine was convinced that the car battery was dead and bought a new one - which actually solved nothing. It was the battery in the fob all along.
Old 09-25-13, 11:45 AM
buckeye101
buckeye101's Avatar
My dealer, Lexus of Dayton, has twice now replaced the battery in im FOB for absolutely free. No wait, strike that, I ate a cookie and had a cup of coffee (in th 15 minutes that theys spent).
Old 05-26-14, 12:59 AM
davidhumph
davidhumph's Avatar
my key is not work at all
Old 05-26-14, 06:07 AM
barrylav
barrylav's Avatar
Default barrylav
I just replaced the battery in my fob as I couldnt gain access without the key and although I am getting a light in the fob the fob is still not opening or locking the car. It was fine last night, any ideas anyone.
Old 06-09-14, 07:55 AM
shaolin
shaolin's Avatar
Last two years i've replaced 2 batteries and now my fob sometime will and will not detect. How long do you think the battery should last? Shouldn't this type of battery last for years...?
greglawes (10-20-22)
Old 06-09-14, 03:11 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
From what I've seen, they typically last between 12-24 months, depending on how much you use them and if you keep the remotes near some electrical devices (microwave, TV, etc.) that can make them die faster as well.
Jeff
Old 06-10-14, 08:34 AM
shaolin
shaolin's Avatar
Jeff
Factory came with Panasonic so i'm gonna try a different brand this time hopefully it'll last a bit longer. Hopefully nothing wrong with my remote....
Thanks Jeff!
Old 02-25-15, 06:46 PM
LISAF3R
LISAF3R's Avatar
Well I was left stranded today. I was just at the dealership here 2 months ago getting a free replacement battery. So I didn't think it could be that already. I tried like 20 times to get it started. I guess I was in denial lol. I ended up causing the brake pedal to get stuck down .. to where there was no play when car was off. While I waited to ditch my car and be picked up.. I decided to actually bust out the owner's manual and read. CR1632 battery. This battery was actually hard for me to find. Walgreens was out, walmart was out, finally Radio Shack had this. One battery for $6 or a 3pk for $13. Got the 3 pack and replaced the battery. Went back to my car and tried. Nothing. Pissed! A warning/notification came on about needing to push the brake to start the car. So I just put both feet on the brake pedal and pushed with all my might, hard.... then finally it started. It released and all was good. Here's a pic of the page in the manual for future reference for anyone who doesn't have it handy.
Old 02-26-15, 09:35 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Make sure to read the section in the manual about starting the car once the battery dies, you should have been able to start the car with a dead fob battery by holding it up to the switch (emblem side facing the start switch) for about 10 seconds.
Jeff
Old 02-26-15, 10:13 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
$6 is pretty steep...I got mine for ~$2
Quick Reply: Key not detected...
