slotted rotors
Old 08-02-09, 09:51 AM
jazba
jazba's Avatar
Default slotted rotors
Are slotted rotors worth it? I am thinking of getting StopTech Powerslot rotors and wanted to know if anyone else is using them. Also, do you have to get aftermarket brake pads if you want to use those rotors or will OEM work?
Old 08-02-09, 09:57 AM
iSuxeL
iSuxeL's Avatar
If it is just a replacement rotor then you can use OEM pads. IMO I think they're worth it.
Old 08-02-09, 10:07 AM
Phiber
Phiber's Avatar
you might want to look in this thread..
https://www.clublexus.com/forums/sus...ed-rotors.html
Old 08-02-09, 02:33 PM
soupdawg
soupdawg's Avatar
as far as performance go they are worthless. if you want it just for looks then go ahead
Old 08-02-09, 03:10 PM
juice14
juice14's Avatar
my 1st brake job ill get some just for looks, performance is 0 improvements as far as i know
Old 08-03-09, 05:08 PM
aboss3
aboss3's Avatar
Not much improvements....you'll burn those anyway when u go to the track
Old 08-03-09, 06:41 PM
montgb
montgb's Avatar
The OEM rotors provide plenty of bite already - its very doubtful that you'd feel a difference with slotted rotors. A bonus would be if they weigh less than the OEM rotors.
If you're going for a more aggressive look, go for drilled rotors. IMO, they're more eye-catching than slotted rotors. Some would argue that drilled rotors aren't as robust as OEM or slotted, but if you're not tracking your car every weekend, you will have no problems.
bigblack06
02-08-12 12:29 AM
SlickRSM
Suspension and Brakes
06-29-09 09:43 AM
coldbay
12-12-08 10:06 PM
rclab1
04-03-07 10:54 AM
spxChrome
02-28-03 05:59 AM
Quick Reply: slotted rotors
