Foglight fuse blew?
Old 01-22-14, 05:47 AM
TheVille
TheVille's Avatar
I picked up a 10 amp and 15 amp fuse yesterday. I can't seem to find which fuse to replace. Any help?
Old 01-22-14, 11:57 AM
tungc124
tungc124's Avatar
It is a 15 amp fuse, fuse box located on the drive side. Once you located the fuse box, look to your left, there is a slot that you need to pull out. once you pulled that out, fog should be on the bottom side of the slot and its color coded blue. (if i remember correctly)
however, there is a strange thing tho, original fuses are shorter than the fuses you picked up from auto store (unless you bought it from Lexus)
if you have fitment issue then you'll just need to cut the extra length on the new fuse. (I did it on mine)
PM me if you have any questions.
Old 01-22-14, 03:22 PM
whitebeast
whitebeast's Avatar
for fog light fuse, you have to pull lower left box out to change fuse. it's 15AMP FR FOG IN front controller box refer second pic
15amp FR fog
Old 01-17-17, 01:15 PM
orlando007
orlando007's Avatar
Mines stoped working ill check it out to day and replace it to see if that is the issue.
Old 01-17-17, 02:46 PM
ohiois350
ohiois350's Avatar
If you have HID fog lights installed, I suggest you go with 5 amp higher than the stock, i had mine hid fog installed with the replays harness draw the power from the battery, during the installation ever times i turned it on to test if working correctly, and the fuse keep blow, after five fuses blow i got them to stay on, and it last for about two years and the fuse blow again, this time I upgraded to 20amp versus 15amp stock fuse, and it been fine since last July
pentiumvi
RX - 4th Gen (2016-2022)
38
01-16-24 05:33 PM
g356gear
IS F (2008-2014)
10-10-12 04:18 PM
Dx3
SC- 1st Gen (1992-2000)
04-09-10 01:29 PM
spxChrome
07-10-06 04:54 PM
ivc
08-02-01 10:21 AM
Quick Reply: Foglight fuse blew?
