installing wiper blade help???
Old 11-15-06, 06:06 PM
sjgIS350
sjgIS350's Avatar
Default Wiper replacement
Anybody know how to replace the wipers? Do you have to replace the wiper blade or can you just replace the refill/rubber? I took a quick look and it wasn't obvious to me how they came off the arm?
Here is what I mean by the various parts mentioned
Refill/rubber - the rubber part
Blade -the metal part that houses the rubber
Arm - the part that connects the blade to the wiper motor assembly
Old 11-15-06, 07:14 PM
Tammy
Tammy's Avatar
You may find this informative ...
http://rx300how2.home.comcast.net/wiper_blades.htm
It relates to the RX but your wiper arms and blades should be similar.
I use dealer supplied rubber inserts; they provide better wear and last a reasonable time...
File Type: pdf
Old 02-28-07, 04:46 PM
rhsmd
rhsmd's Avatar
Default wiper blade replacement
has anyone changed out wiper blades?
nothing in it in the manual. is it replacing just the refill or the entire blade?
Old 02-28-07, 06:41 PM
jsquared
jsquared's Avatar
i was wondering too, but i'd assume its just the actual blade (that touches the windshield), because the top of the right wiper has the rain sensor (for those of us that have them).
Old 02-28-07, 06:45 PM
rhsmd
rhsmd's Avatar
no. the rain sensor is in the windshield above and to the right of the rearview mirror.
Old 02-28-07, 06:59 PM
Cleric
Cleric's Avatar
Refills are available so you don't have to replace the entire blade assy.
Old 02-28-07, 07:26 PM
jsquared
jsquared's Avatar
wow really? so what's that small little square thingy sticking out of the right wiper?
Old 02-28-07, 09:57 PM
rhsmd
rhsmd's Avatar
i have to look on my car. can you post a pic.
Old 02-28-07, 10:30 PM
IronPhoenX
IronPhoenX's Avatar
Has anyone fit the PIAA Silicone wiper refills on their stock wiper frames? I really liked those blades on my last car. They put a coat of silicone on the glass and acts better than Rain X. Lasted me over 4 years.
Old 03-01-07, 12:52 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Interesting. The whole reason I use Rain-X is so I don't have to turn on the wipers.
Old 03-01-07, 07:15 AM
bagwell
bagwell's Avatar
+1
I've had the car alsmot 2 months and haven't used the wipers yet but I might try the PIAA Silicone blades.
Old 03-01-07, 07:27 AM
shaolin
shaolin's Avatar
I think the factory wiper is really good and maybe one of the best I ever had on cars. I am not too sure why some people wants to change it. Please advice.
Old 03-01-07, 07:36 AM
chuckler
chuckler's Avatar
whoa piaa's are cool...where can i get that? online only? can i just get the refills or do i have to get the whole assembly?
i agree that the factory wipers are good..but they dun last forever shaolin and i'm always open to try something new like the piaa's
Old 03-01-07, 07:37 AM
shaolin
shaolin's Avatar
^icic.
I won't be replacing mine anytime soon so I guess I will wait and see some other cl memeber's comment on aftermarket blades.
Old 03-01-07, 07:51 AM
neova
neova's Avatar
I agree. The OEM wiper blades works fine. It's quiet and it does it job nicely.
One danger in changing just the rubber insert, as opposed to the entire blade assembly, is that you need to be careful the rubber insert is attached properly and securely without any loose spots. If there are any loose spots then when the blade changes direction, it will produce a squeaking sound because there is movement between the blade and the rubber insert.
I would just go and buy another OEM blade assembly when it's time.
Quick Reply: installing wiper blade help???
