Excessive Rear Tire Wear on AWD plus low speed wobble, anyone?
Old 03-25-09, 12:46 PM
phattie
phattie's Avatar
Default Excessive Rear Tire Wear on AWD plus low speed wobble, anyone?
my apologies if this has been answered. i have a couple of things going on.
vehicle: 2007 is250 awd
notable mods: tanabe nf210 springs. bbs ch 18 x8 rims on continental extreme contact 235/40.
1. has anyone else experienced what seems to be a slow speed (13-17mph) wobble? feels like it's coming form the rear. rims are straight.
2. i go through rear tires very quickly (2 sets of rear tires in the past 18k miles). i suspect that the slow speed wobble might have something to do with this. any idea what would be causing this? is this a side effect of lowering?
many thanks to the tire and suspension pros for your help.
nelson
Old 03-25-09, 01:06 PM
PaPaHoFF
PaPaHoFF's Avatar
my car is actually starting to wobble and shake. I am going to get another alignment but if it still happens then im clueless.
Old 03-25-09, 01:20 PM
fdelement
fdelement's Avatar
check tire pressure and make sure they're torqued to spec
Old 03-25-09, 02:30 PM
mvlbr
mvlbr's Avatar
You probably need to check the balancing on your wheels and the alignment.
Old 03-25-09, 03:14 PM
blksrpnt
blksrpnt's Avatar
agreed!
Old 03-25-09, 03:53 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,848 Likes on 2,333 Posts
nelson
Be sure the shocks are still good. We've seen a few shocks fail with very low mileage. A blown shock could give the symptoms you are experiencing.
Old 03-25-09, 04:54 PM
Evil Teo
Evil Teo's Avatar
i am experiencing this as well but my tires still look good. i hope its not anything major but will fix after i come back from cali.
Old 03-25-09, 05:08 PM
phattie
phattie's Avatar
ok guys. I'm going to give another shot with yet another set of tires and a fresh a allignment. I'll have the shocks checked too.
Nobody thinks the tanabe springs have anything to do with it?
Nelson
Old 03-25-09, 07:55 PM
laobo979
laobo979's Avatar
hmmm cant say that i have with my AWD but my car dumped on coilover for the last couple months
Old 03-25-09, 08:00 PM
LEXisJaDeM
LEXisJaDeM's Avatar
i have the same problem...8k miles and my rear tires are gone..had the alignment done when i lowered the car at 3k miles and camber wear was bad on the tires..just had the car realigned with toe adjustment and new tires are on the way..this may be the same issue with your drop...im just hoping once i get the new tires, i dont have to cough up money every 8k miles for new tires.
Old 03-25-09, 08:08 PM
Evil Teo
Evil Teo's Avatar
i think the tire wear is due to the springs as solo stage went through the same situation with the tanabe springs. she had to replace the tires very often. the wobble u experience may be due to the shocks givin out.
Old 03-25-09, 09:01 PM
PaPaHoFF
PaPaHoFF's Avatar
word if that is the case lmao I am going to just have to buy coils...
not perfect excuse to buy coils lmao!
Old 04-02-11, 04:16 AM
CarbonDtls
CarbonDtls's Avatar
The tire wear is not because you have springs its because your camber is off or toe is off. The wobble seems to be an issue with the awd models but people are still looking for a fix.
Check to see if any of the shocks are leaking, you could also push down on each corner of the car and see if they all react the same.
Old 04-02-11, 04:44 AM
Phresh2010
Phresh2010's Avatar
i have tein springs on my AWD for the past 6000 miles, i had an alignment done right afterwards and i have even tire wear and no wobbling, my guess is your alignment
Old 04-02-11, 06:50 AM
CarbonDtls
CarbonDtls's Avatar
Make sure you get a print out when you go for an alignment. Most techs at large shops(firestone, midas) have very minimal experience with lowered vehicles and don't understand fully the extent of running excessive on a daily driver.
Quick Reply: Excessive Rear Tire Wear on AWD plus low speed wobble, anyone?
