Bad Gas!
Old 03-11-09, 02:19 PM
Katyfan
Katyfan's Avatar
Default Bad Gas!
I randomly filled up at a Citgo station here in Houston because I was heading to a wedding and was running low. After the wedding, my car would barely start and jerked like hell on the highway. i took it to the dealer and the said it was definitely the gas. They say it will run around $400 to clean everything out. Does this sound reasonable, and how do I approach the gas station about covering the charges?
Old 03-11-09, 02:33 PM
blk250
blk250's Avatar
too much $$ I guess. Can you syphon what ever left in the tank? and put in new gas..
Old 03-11-09, 03:05 PM
llamaboiz
llamaboiz's Avatar
hehe try BEANO
Old 03-11-09, 03:23 PM
tqlla3k
tqlla3k's Avatar
Do you have an IS250 or 350? dont criminals syphon gas all the time? Cant be that hard? IMO, just do that to your car for about 10 gallons or so. Then fill the rest with Premium
Old 03-11-09, 03:37 PM
highstakes
highstakes's Avatar
You probably used E85, one of my sisters made the same mistake with my TSX; just siphon it out and put in whatever you use.
Old 03-11-09, 03:56 PM
Maxximus
Maxximus's Avatar
could have been water or mud/dirt in the gas as well
Old 03-11-09, 05:37 PM
iLexi
iLexi's Avatar
your lucky the gas did have water in it. We had a hurricane in fl, the water got into the gas line. It shut down my hommies car n he had to pay a couple g's to fix it
Old 03-11-09, 05:43 PM
johnch
johnch's Avatar
For what it's worth. There is a rating for gasoline known as Top Tier Detergent Gasoline. To qualify, the gasoline needs to meet a level of detergent additives beyond that which the EPA requires. Informative web site and the retailers rated as selling Top Tier Detergent Gasoline here:
http://www.toptiergas.com
John
Old 03-11-09, 05:56 PM
herbvdh
herbvdh's Avatar
Just put in a tank of Premium from a good brand gas station or if you have Shell by you use there top of the line gas which is above your standard Premium. I learned years back never use Citgo gas. I did years back while on my honeymoon I got the car started in the morning backed out of my parking space stopped put the car in drive and it stalled out. I wound up under the hood trying to free the carburetor up due to extensive gum in it. Keep in mind I closed a parking lot where I stayed for about ten minutes till I got the car running again.
Old 03-11-09, 06:18 PM
09 LEX 250
09 LEX 250's Avatar
shell or chevron 91
Old 03-11-09, 06:27 PM
mvlbr
mvlbr's Avatar
Shell, Chevron or 76 are the only brands I ever use.
Old 03-11-09, 06:37 PM
AZ06IS350
AZ06IS350's Avatar
John
I used to be a faithful Chevron or 76 gas consumer. Then when prices started to skyrocket, I would go for the cheapest I could find which in my area was a Quik Trip gas station. I'm glad to see that QT is on the list of "Top Tier" Retailers!!!
Old 03-11-09, 07:39 PM
badx33
badx33's Avatar
man the same thing is happening to me right now, man its jerking really bad and my exhuast tips are really black. i think i made the mistake of letting the gas level go tooo low, i dont know if it was the gas station i used, i only use hess, chevron, and shell, now my mechanic friend said to use amoco bp. hopefully this works.
Old 03-12-09, 04:29 AM
Kurtz
Kurtz's Avatar
The guy probably got contaminated gas.
Using a certain brand won't really help you avoid that.
-all- gas sold in the US is required to meet minimum standards that will avoid the issues this guy is having. But if a particular station gets crap in their underground tanks no amount of marketing hype about the "tier" of that brands gas will help you.
(and if he put E85 or something in there, again, the marketing brochure for the brand wouldn't have helped him).
Old 03-12-09, 05:56 AM
Feirax
Feirax's Avatar
Before you spend that money, I would try a can of Dry Gas and see if it gets better. The Sunoco station by my house (which I've stopped using) would occasionally leave me running rough, and dry gas would fix it every time. They usually even carry it at the gas station.
Quick Reply: Bad Gas!
