Lexus Announces Safety Recall on Select Vehicles
Old 02-19-09, 04:49 PM
  #226
Lets Drive
Lets Drive's Avatar
Originally Posted by Foodplz
I had the recall done about 2 weeks ago. I'm starting to notice that my car makes a "clunk" noise during acceleration. usually between 30-40 mph. the second i let go of the gas... "clunk".
I took everything out of my trunk... including my spare. Still makes the noise.
Anybody else have notice this problem after the 3 recalls? Its the oddest noise.
Thanks.
Which dealer in MD did your service work?
I got mine back from the dealer today, and haven't noticed anything abnormal, thus far.
Old 02-19-09, 06:51 PM
  #227
Foodplz
Foodplz's Avatar
Lexus of Rockville.
Yea I don't think this happened to anybody else... I'm starting to think it has nothing to do with the recalls.
Old 02-20-09, 04:19 AM
  #228
ajmtbm
ajmtbm's Avatar
Originally Posted by mikeho
LoL. Finally got my car back. What got changed:
All 3 campaigns: Rear Brake Pins, Electronic Steering, Fuel Pipes
TSIB: Cold Start Noise
Problem: Check Engine Light On -> Exhaust Valves (all 12 of them) and Valve Springs (all 24 of them) replacement
Total Cost to Lexus: $10619.
Damn.
how do you know the cost?
how much of this was the brake pins, steering rack, and fuel pipes? thats what i am getting and i am curious.
Old 02-20-09, 04:25 AM
  #229
ajmtbm
ajmtbm's Avatar
Originally Posted by AgBlue
Hey all,
I finally got my car back from the check VSC and gear issue. They did the all three recalls for my model as well as changing the O2 sensor and my transmission.
My initial thoughts....
1. The steering is significantly heavier and tighter. Turning out of the dealership required much more force than before. Although it's too early to say if I like it better. It doesn't feel as smooth as it did before, but the heavier feel does make it seem a bit more sporty. Then I drove on the interstate and this was the part that I did not like. At 60-70mph the steering wheel has a slight play in it for about an inch or two to the left and right of center. Turning it slightly an inch or so is good enough to change a lane. However, it seems to wobble just a bit too much. Turning it past the 1-2 inches feels tight like it does at slow speeds.
2. My brakes do seem to bite down tighter as they probably bleed the system. Feels good. I do need a to change my brakes tho.
3. New transmission feels good. Changing gears feel smooth, and seems normal. I noticed shifting the car into drive/reverse/etc feels a bit tighter too, tho it could just be in my head (I did drive the loaner for almost 2 weeks).
Total time to do the recalls:
3 full days for all 3 recalls.
1 day for my transmission
4 days for all the parts to come in
1-2 days to diagnose transmission
(Dropped off 1/16/09 evening - Picked up 1/28/09 evening).
What is the transmission recall, first I heard of this? Anyone have any info?
Old 02-20-09, 08:09 AM
  #230
holYcOO
holYcOO's Avatar
For the 3 recalls, when signing the papers, The total was around $1400 and Labor was around $750. To conclude parts were around $700.
Old 02-23-09, 05:12 PM
  #231
gixxrr
gixxrr's Avatar
Mines been sitting at the dealership for a week
The RX loaner car is just not the same.
Old 02-23-09, 07:42 PM
  #232
lexus5703
lexus5703's Avatar
I just got my letter today and am taking it in on Thursday!
Old 02-24-09, 09:15 PM
  #233
LexyIS350
LexyIS350's Avatar
Well, just got all three service bulletin and a gear like noise with the telescopic steering completed by Lexus of Pleasanton. I have to say it took a little longer than expected but that's because they needed to order a new guage assembly for a separate issue. They loan me a RX 350 for the week while the service was getting done. Overall very good service from my service manage Jason Portillo and the car came back like it went in except washed and a full tank of gas. I also noticed while looking through the service documents that they also attached an alignment readout. I guess they needed to perform an alignment after installing the steering rack. I would recommend them if you need to get these safety recalls done.
Old 02-25-09, 08:48 AM
  #234
RocketGuy3
RocketGuy3's Avatar
Can someone tell me what the noise is that the rear brakes are supposed to (sometimes) make before this service campaign is done?
Is it like a high pitch squealing noise?
Old 02-28-09, 01:47 PM
  #235
HERBos
HERBos's Avatar
Default recall?
my friend just told me that lexus is having a recall on the 06-07 is cars. they're keeping the cars for 2 days and replacing the steering wheel. does anyone know if this is for the 08 is models as well?
Old 02-28-09, 01:58 PM
  #236
iSuxeL
iSuxeL's Avatar
The STEERING WHEEL?? or steering rack and pinion? Cause that's with the fuel rail recall. I would call your local Lexus dealer and ask if your car is on the list for the recall.
Old 02-28-09, 02:05 PM
  #237
IS-SV
IS-SV's Avatar
The steering rack is with the fuel rail recall? How does that work?
Old 02-28-09, 03:32 PM
  #238
tex2670
tex2670's Avatar
My car was in 2 weeks ago--no mention of steering recall. They did the fuel line recall. they did have to keep it a second day, but only b/c I had them hunting down a creaking noise. If it weren't for that, it would have been done by day's end (I couldn't hang around waiting to hear from them if it was going to be finished the first day).
Old 02-28-09, 04:55 PM
  #239
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Threads merged. Please search for recalls before starting new threads.
Old 03-01-09, 09:54 PM
  #240
RocketGuy3
RocketGuy3's Avatar
Second try:
I ask because right now my car sometimes makes a squealing noise when I'm slowing to a stop, and it has done this both before and after the rear brake service campaign... I feel like it is more frequent when the weather is colder.
Quick Reply: Lexus Announces Safety Recall on Select Vehicles
