Need Help, I don't know how this happened...
Old 11-30-08, 01:10 PM
shinbrianj
shinbrianj's Avatar
Default Need Help, I don't know how this happened...
So friday night I was driving, I was on a local road going about 25mph and I hear all this noise from my right rear wheel. So I pull over and to find out I have a flat. I look around and can't see any debris on the road or any potholes. So I assume its a nail but while putting on the spare I see there is a hole in the rim (Five Axis S5:F). So I look on the tire and can't find a nail or a hole, just a little piece of the rubber came off. So somehow the rim has a big whole and to top it off the broken piece of rim went through my rear bumper making a crack. Any thoughts? Has this ever happened to anyone? Could it be a defective rim or tire? I've only had it for less than 6 months. Its always properly inflated and never over inflated.
Old 11-30-08, 01:27 PM
venZon
venZon's Avatar
wow have never seen that?
Old 11-30-08, 01:29 PM
is4fsr
is4fsr's Avatar
Looked like u hit something long and sharp to puncture your tire and rim. Doubt it's a defective tire or rim from the pics you have. Any foreign object inside your tire?
Old 11-30-08, 01:31 PM
montgb
montgb's Avatar
Ouch! It looks like you ran over a nail and it was long enough to puncture the barrel of the wheel as well. It must have been really long, too, since you're not running low-profile tires. Weird.
Old 11-30-08, 01:32 PM
shinbrianj
shinbrianj's Avatar
There is just a little chunk of the tire missing but couldn't find a hole, and I've rolled the tire around and cant hear anything inside. My first guess was something punctured it, but wouldn't that leave a hole in the tire? 235/40/18 is the tire size =(
Old 11-30-08, 01:36 PM
mikez
mikez's Avatar
Can you push your finger into the tire through that thing? or did it not penetrate the tire?
From the look of the rim damage, it seems either something came through and blasted through it, or the rim has a defect around that area and an sudden increase in pressure from someone hitting the tire around that area popped it.
If you get a high enough compress air to hit a peice of metal like that, you will get similar damages.
Old 11-30-08, 01:40 PM
montgb
montgb's Avatar
That is odd! Maybe it was a sharp rock that didn't actually penetrate the tire but hit the wheel with enough force to damage the rim. Your tires were properly inflated, right?
Old 11-30-08, 02:02 PM
Johnny
Johnny's Avatar
Looks like a rifle bullet, if you ask me. The rim is repairable. Most cities have alloy rim repair centers. They weld the hole and if necessary machine and repaint the rim, although in your case that should not be an issue. The cost should be around $120 or so. The tire itself may be repairable depending on the size of the damage, but you may want to check if it is still under warranty.
Old 11-30-08, 02:55 PM
ChrISF
ChrISF's Avatar
wow that is strange. never seen anything like that before.
Old 11-30-08, 03:08 PM
radicalrev
radicalrev's Avatar
i think some1 shot at your tire....lol
Old 11-30-08, 03:14 PM
ek9vboi
ek9vboi's Avatar
Seeing that you said the rim is aftermarket, how was the TPMS installed (if you did)? If you drilled or used those straight TPMS adapters it could have caused the hole when you ran something over. BUT then again u said you didn't hear anything after rolling it around... odd.
More then likely, something metal went through the wheel and tire.
Old 11-30-08, 03:36 PM
VikH
VikH's Avatar
No wonder the wheels are so cheap.
Old 11-30-08, 04:33 PM
kgh31386
kgh31386's Avatar
boom headshot. really does look like someone shot at it. unless you ran over something big and long and it shot out after you ran over it...screwdriver? something similar happened to my car, a rock managed to make its way in between the spokes...so i got a nice gash. a wheel spinnin at 80 doesnt like a rock to get tossed in there.
Old 11-30-08, 07:46 PM
royal5fan
royal5fan's Avatar
Cross any rail road tracks? Could have been a rail spike.
Old 11-30-08, 11:49 PM
Little E
Little E's Avatar
Yikes! Looks like a warrior speared your wheel.
Quick Reply: Need Help, I don't know how this happened...
