Old 01-06-15, 04:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
DIY JDM LED Side Signal Mirror Covers *56K Warning*
Old 03-03-14, 09:23 AM
  #226
Ants350
Ants350's Avatar
Just finished this job lots of work man!
Old 03-05-14, 04:21 PM
  #227
runyun
runyun's Avatar
Thank you OP. Just did it last week on the GF's car.
(I installed Nigel mirrors on my GS last year so I have some experience)
But finding those signal wires under the drivers sill was a time saver.
How I was able to find the green/dark pink wire on the first try still amazes me! LOL
Took me a few hours
Wanted to jump in and say thanks again
Old 05-30-15, 11:46 AM
  #228
lexuscanuk
lexuscanuk's Avatar
Hi, I know its this thread is a bit old but i thought i try my luck anyways. My car side rearview mirror (driver side) has a crack thanks to a salt truck. Anyways, I looked online and everybody wants to sell me the entire unit. I was just looking for the shell of the rearview mirror assembly. I was wondering of those of you that did the conversion and had the original shell. Do you want to sell it to me and how much? thanks. My car is dark grey by the way but color does not matter too much.
thanks.
Old 06-01-15, 06:40 AM
  #229
Kasim
Kasim's Avatar
thanks.
I was in the same boat, try to look at junk yards, there's a website, can't remember which one,
will search by part #. and i got a good price on entire mirror.
I had to buy entire mirror but only used mirror not casing, but you are not lucky, my was pass side, otherwise i could sell it to you.
Old 11-17-15, 03:40 PM
  #230
adpock
adpock's Avatar
Default How To Tuesday
Here's another good resource...
https://www.clublexus.com/how-tos/a/...mirrors-365647
Old 01-07-16, 02:18 PM
  #231
Nabil250
Nabil250's Avatar
Great DIY thanks a lot
Old 06-22-17, 08:34 AM
  #232
Dayron
Dayron's Avatar
Where did u buy the Side mirror ?
Old 04-19-19, 06:03 PM
  #233
iGary
iGary's Avatar
Default Wiring DRL model on 06 is250
Does any one know which wire to tap for the DRL wire as the version below? I followed exactly what T mentioned for the turn signal light to work but couldn’t figure out which wire I should tap for the DRL wire. I’d just need that to be tapped on the wire for Auto lights on if that make sense? Any help would be greatly appreciated!!
Old 04-26-19, 09:51 PM
  #234
sinister2c
sinister2c's Avatar
I installed last year and wired the parking lights to the illumination wire for the window switches in each door. I think it’s a green wire but should multimeter it.
I ran ran the turn signals all the way to the turn relay next to steering column. Single wire each side and grounded inside each door b
Old 01-08-24, 12:44 PM
  #235
vicGrey2ISPR787
1st Gear
vicGrey2ISPR787's Avatar
Default Grounding
greetings . thanks in advance. Following your steps great info. just need to know where did you ground ? Im doing the wiring in advance cause i ordered the ones mstyle w blinkers for my 08
nikkatrung
05-15-12 12:32 PM
sleepyray
IS F (2008-2014)
16
03-01-12 09:36 AM
LZMF1
GX - 1st Gen (2004-2009)
22
07-15-11 12:42 PM
XprincoX
05-11-10 09:58 PM
Cali2is
19
12-15-08 04:13 PM
Quick Reply: DIY JDM LED Side Signal Mirror Covers *56K Warning*
