Old 12-15-14, 04:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
How To: Replacing Side Mirror Puddle Lights w/ PICS!
Old 02-19-12, 01:33 PM
  #121
sleepyray
sleepyray's Avatar
I spent 45 mintues tried to remove the puddle lamp.....after i removed that 2 screws and crack the cover open... no mater how i pull and twist the len....it just won't come out....
I have a 08 IS-F... can someone please tell me if it's DIY are same on my car or not...
Old 02-19-12, 05:51 PM
  #122
sleepyray
sleepyray's Avatar
got it done!.....i found it much more easier to removed the mirror, removed the cover, loosen the 4 screws and then change the bulbs.
Old 04-26-12, 07:04 PM
  #123
Vibes63
Vibes63's Avatar
Great job!
Old 04-26-12, 09:26 PM
  #124
AndysIS
AndysIS's Avatar
can anyone help but i brought the 4 LED 2W HP flank bulbs and i for some reason couldn't get them to come on i did noticed when i looked inside the housing of were the leds go its scratched as if the tip of the 4 LED 2W HP flank bulbs scratched the inside housing and i did pull it out a tad bit so that it wouldn't go all the way in then i tried to push it all the way in didnt work and i tried many ways but sometimes it would turn on for a quick second or 2 then shut off any help i would appreciate
Old 04-27-12, 06:32 AM
  #125
Joeb427
Joeb427's Avatar
The so called 'new and improved' VLEDs 4 LED flank is too long now due to an added heat sink..
My buddy Koz here and I installed a set of the new 4 LED flanks in my new ES.
You have to modify the LED and the inside housing.
The bulb needs to be Dremeled to make shorter and the inside housing needs to be Dremeled a bit so the LED can fit.The LED will leave a black mark from hitting the lens housing in the area where you have to Dremel a bit without going through the plastic housing.If you do go through,a simple dab of silicone will work.The lens housing is not exposed to the weather.
Not too big of a deal but still a pain versus the older version of the LEDs fit perfectly in my other Lexus'.
There might be other ways to modify but this way worked for me.Of course this is all assuming the IS and ES have the same housing which i would think they do.
The new LEDs do look good,though.
You can always go with the VLEDs 2 LED flanks which will fit but they're pretty weak on light output but white.
Old 04-27-12, 07:37 AM
  #126
Vibes63
Vibes63's Avatar
Great modification!
Old 04-28-12, 12:15 PM
  #127
AndysIS
AndysIS's Avatar
Thans sounds like the same problem im running into so ill try this and see if it works will I damage the led shaving some of it off
Old 04-28-12, 01:51 PM
  #128
Nelly
Nelly's Avatar
Need help on the 09+ :/
Old 04-28-12, 05:09 PM
  #129
Mikaveli
Mikaveli's Avatar
here guy's i just ordered the led interior swap and i couldn't find a universal thread but i came across this and it shows how to switch everything hope it helps
Old 02-07-13, 01:10 PM
  #130
LWKT
LWKT's Avatar
I was reading up and noticed these posts are a bit old, so I just looked at the V-LED website, looks as tho they have fixed this problem. The info at the bottom of the flank 4 LED says that " NEW SIZE! Will fit 06 up Lexus IS puddle light application. "
Just thought id put this up here.
Old 06-09-13, 06:50 PM
  #131
mililani00
mililani00's Avatar
My puddle lights went out, is there a fuse or something ?
Old 09-12-13, 09:25 PM
  #132
tofupunx
tofupunx's Avatar
Originally Posted by Mikaveli
here guy's i just ordered the led interior swap and i couldn't find a universal thread but i came across this and it shows how to switch everything hope it helps http://www.youtube.com/watch?v=uZFtrx2RiaE
That's awesome!! Thanks for posting.
ICU2
05-02-14 09:02 PM
zackteee
12-01-13 09:42 PM
SilentWish
09-01-10 08:33 PM
LEXuriouss
SC- 1st Gen (1992-2000)
01-22-07 12:46 AM
Quick Reply: How To: Replacing Side Mirror Puddle Lights w/ PICS!
