Thinking about repainting some parts
Old 11-06-08, 01:36 AM
ntoxicated
ntoxicated's Avatar
Default Thinking about repainting some parts
Hey guys,
I'm thinking about repainting parts that were damaged from an accident at a local body shop.
But I wanted to clear up some things before I let the guy do it...
So tell me if I'm getting things wrong I'm still a NOOOOB,
1) Base color means single stage
Base coat + clear coat means 2 stages
base coat + lots and lots of clear coat still means 2 stages, right?
2) Lexus IS Black Obsidian (some people say Black Onyx) is a single stage, meaning no clear coat only base?, which also means you spend less money on paint material? Because I heard that clear coat is the expensive thing and the more and more you add clear coat, more expensive it gets?
3) Does anyone know what brand was used to paint IS 250 black obsidian cars in the factory? Hope they didn't use Japan products...I understand that in a factory it's a whole different process (high temperature) but couldn't we use same brand and same line at least... I want to match the factory paint as close as possible.
4) So each paint brands also have different quality lines, right? And for example, is PPG's Omni good enough for factory level?
5) And a stupid question... does cold weather have any impact on painting job? I know the shops have inside painting place..oven? but I was just wondering...
Thanks in advance for your comments!
Old 11-06-08, 08:49 AM
darkdream
darkdream's Avatar
1) Yes
2) obsidian and black onyx are two different colors and all have clear coats
3-Stage IS Colors (basecoat/midcoat/clearcoat):
8U0-Black Saphire Pearl
062-Crystal White
074-Glacier Frost Mica
3R1-Matador Red
077-Starfire Pearl
2-Stage IS Colors (basecoat/clearcoat)
202-Black Onyx
8P8-Blue Onyx Pearl-5 Variants!
8R6-Breakwater Blue Metallic-3 Variants
6U3-Desert Sage-2 Variants
4P7-Mystic Gold Metallic-2 Variants
212-Obsidian
1G0-Smokey Granite Metallic-2 Variants
1G1-Tungsten Pearl-1 Variant
This is from the DuPont Automotive Color Guide.
3) Dupont
4) Yes
5) not sure
Old 11-06-08, 05:21 PM
ntoxicated
ntoxicated's Avatar
Surprising that Black Obsidian is a two stage... Then to match the factory-level, how much clear coat is should I put up there?
And what line/branch from Dupont would it be?
Old 11-06-08, 06:52 PM
javyLSU
2IS OG
javyLSU's Avatar
^You shouldn't be surprised. OEM manufacturers stopped using single-stage paint systems in the 1980's...
Javier
Old 11-06-08, 08:27 PM
CAIFAN_64
CAIFAN_64's Avatar
Javier
Old 11-06-08, 09:13 PM
ntoxicated
ntoxicated's Avatar
Javier
I was confused cuz many people were arguing it's a single stage..
So.. three coats of base + two coats of clear would be good match with factory?
Any recommendation on what to use from Dupont?
Old 11-07-08, 05:04 AM
s6 4rings
s6 4rings's Avatar
You are overthinking this too much. Find a reputable shop and put your trust into them.
Old 11-07-08, 05:10 AM
radicalrev
radicalrev's Avatar
yep! over thinking this too much...just go to a reputable body shop....all modern car's paint have clear coats unless it has been repainted single stage...
Old 11-18-08, 07:29 PM
exvelocity
exvelocity's Avatar
Javier
wonder who told you that,
toyota still uses single stage paint till this day
I know for fact 202,040 that came on MKIV Supras has no clearcoat
040 that came on just about every Toyota has no clearcoat,that is why when you see a few years old white Toyota,it looks faded & chalky, Camrys and Corollas are notorious for that
not to be a smart-*** or anything,but I've been in automotive body/paint industry for nearly 20 years
and to the OP, just find a reputable shop and stop thinking too much
Stefan
Old 11-18-08, 09:50 PM
sinister2c
sinister2c's Avatar
probably doesnt matter cuz the body shop will use basecoat clear coat to paint it anyway.
Old 11-18-08, 10:40 PM
crazybuggy
crazybuggy's Avatar
Thumbs up
wow, im learning a lot about this whole painting thing from this read! thass wassop!
tstead
ES - 5th Gen (2007-2012)
04-07-07 06:49 AM
alonzov
01-10-06 07:03 AM
sha4000
Automotive Care & Detailing
15
12-03-05 03:24 PM
LEXISM
07-14-05 03:13 PM
Kyle Harty
04-16-02 08:23 PM
Quick Reply: Thinking about repainting some parts
