is it a low presure light or a error light? i get a error light once in a while i am takeing it in to get it checked out. usaly after 3-5 times starting the car it will re set for both
well i threw the TPMS in the spare because my rims are not compatible. and the low tire light is still on.... do i need to drive it around for a little for it to recognize it again or something?
no the light will stay on until the TPMS sensors detect the correct pressure of air. you will need to install tires that are TPMS compatible to make the light go away. there's also a work around if you want. that is to go make a can, pipe or bottle with pressurized air that matches the TPMS settings. that way when the tpms running off this "pipe" it'll trick the system. there's a DIY guide for you if you have aftermarket non-TPMS compatible rims. you can make a pipe out of a design (such as a fake NOS tank) and place it somewhere. or just throw the pipe in the trunk.
What air pressure did you put in the spare? If you are getting the "low tire" warning, it is seeing the sensors, but they are detecting a low air pressure condition.
i got the same problem i am takeing mine in tomarrow for check system tmps. also for the seat sweek and my trim keeps poping off or warping around the wind sheild
hey let me know on what they say about the light.... its not the low tire warning anymore its the system check one....i have all my sensors in the spare tire now and everyone i have ask just said drive it around a little and it should go away. i put about another 40 mile since and yet the light is still there
I was also planning on placing a set of TPMS in the spare tire should my new SSR Vienna Zweels aren't compatible with them. The spare tire requires a pressure of 60 psi. That's nearly double the pressure that the sensors require in the stock wheels. Did you inflate it to 60 psi? Did you initialize the new sensors at the dealership?
i ran the stock sensor that came with the car and i put it to 40 psi. gonna go do a late night cruise since everyone says to just drive it around.. hopefully it goes away
Ok i just bought a set to be ready for my new wheels. I have a question on the tpms. Where is the serial that u need to program to the car. I never done this before.
