Fogs On Without Headlights
Old 08-10-08, 04:37 PM
  #31
llamaboiz
llamaboiz's Avatar
so you have to use a separate switch? because the idea is to use the stock switch only for a controllable on/off.
Old 08-10-08, 04:47 PM
  #32
MIA IS250
MIA IS250's Avatar
Wow !!! I am impressed great job!!!
Old 08-10-08, 05:03 PM
  #33
DoHwan
DoHwan's Avatar
dang it! I thought it was completely done through the stock switch as well.. I guess I'll wait a lil longer for someone to figure this out. and if not then i guess I'll just go this route as well... THANX A BUNCH!!!!!!!
Old 08-13-08, 02:08 AM
  #34
crazybuggy
crazybuggy's Avatar
i would like doin this with my car as well!!
Old 08-13-08, 06:21 AM
  #35
Doushiyou
Doushiyou's Avatar
blk250, where did you put your switch? any pics?
Old 08-13-08, 04:46 PM
  #36
blk250
blk250's Avatar
I put the switch next to the gas+trunk switches below the steering wheel.
Old 08-14-08, 11:52 AM
  #37
blk250
blk250's Avatar
trick is to run the wire from the inside to the outside engine bay first, then make connection to those wires (white and green)
Old 08-14-08, 08:14 PM
  #38
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
Never gonna happen with a US spec BEAN ECU. The controls for the lights are multiplexed on the BEAN, and there's no simple way to separate the fogs from the headlights without extra wiring and a switch. I dug deep into this when Technique asked about it (after we figured out how to kill the link between the headlight washers and the windshield washers) and there is just no way to do it with a US spec ECU and the OEM switchgear. Sorry.
And yes, there is no comparison between the 1IS and the 2IS when you look into the wiring. This is why I am still very skeptical the proposed 2JZ swap will work with all the original controls and indicators. If we could just reprogram the engine ECM, we could put anything in there...
Old 08-15-08, 08:11 PM
  #39
D_W_E_85
D_W_E_85's Avatar
Can't you just rewire the foglights to the same wiring as the parking light setting. That way you can run you DRLs and the fogs at the same time. I would think that you should be able to just splice the wire so that the fogs turn on like normal when the HID lights come on but then splice the wire to the wiring for when just the parking lights are on. I may take a look at it and see if it's possible.
Old 03-13-22, 03:05 PM
  #40
sinister2c
sinister2c's Avatar
I did this mod and soldered everything via relay. Some of the info wasn’t correct but I figured it out.
Pin 6 and 7.
Pin 6 and 7 out of the BEAN module goes to the fog lights (one each). You can circumvent that and wired directly to a 15A fuse switched circuit or thru a switch.
I go over all the options in the video.
MNEWGEN (06-26-22)
Old 03-13-22, 05:55 PM
  #41
bakalag
bakalag's Avatar
My foglights are tapped into the engine, they turn on and off with the OEM stalk but only turn on when the engine is on, engine off they dont work.
Old 06-26-22, 04:19 PM
  #42
MNEWGEN
MNEWGEN's Avatar
Just did this mod today @sinister2c thank you so much. The results were great! I'll post up pictures soon! Been waiting years to do this and your video really helped a lot.
Pin 6 and 7.
https://youtu.be/gLJk2pHpWQo
Old 10-23-22, 06:42 PM
  #43
MNEWGEN
MNEWGEN's Avatar
2013FSport (10-24-22)
Old 10-24-22, 10:48 AM
  #44
valeoray
valeoray's Avatar
How did you modify yours to work like that?
Old 10-26-22, 04:09 PM
  #45
bakalag
bakalag's Avatar
Someone did it for me but they cut the power wire and tapped the ignition wire. I don't understand how exactly but that's what he told me. 7 years and still no issues so I guess he did it correctly.
The fog light indicator doesn't light up anymore on the dash but I just leave the fog lights on so I never have to worry, especially after switching to LEDs (useless for function but the old HIDs were problematic)
Quick Reply: Fogs On Without Headlights
