Need 12V for my remote turn on, where can i tap?
my amp won't work properly using the remote tap (pink wire farthest back in the car) b/c it is only 6.5V.
where are people grabbing 12V so that it also turns off with the stereo?
Use the power outlet wire (i am sure its red) it turns on with the car and will give you enough power to turn the amp on. I read this on My.IS because the remote wire near the OEM amp does not give enough power for your aftermarket radio!
How did the rest go?? did those wires work out after all??
Where is the power outlet wire? i saw a red wire near the harness in the trunk but it was always on, even with the car off.
I would use the the power outlet in your armrest if it where me. its closer to where you need the wire and it should be a red wire. then you can run the wire under the carpet through the back seat to the amp! There are only 2 wires that will go to the power outlet. you can tap into the fuse panel als but its up in the very front by the hood release. anything in there that turns on and off with the car you can use. just put the wire in and push the fuse back in and it will force the wire in and you are good to go. you have options here just depends on what is easier for you to do.
lol...I hear ya. I havent removed the armrest in the car. Then what I would do is use the power outlet in front of the radio. If you push the cover back (slide it back) you can pop out what is like an ashtray with a tab. then there are I think 2 screws to remove it. the silver slots on the sides simply lift up easy and they slide towards you. look at the navi hack thread in the FAQ/DIY thread for the 2IS and you will see the removal of that part. you can tap into the wire there then run it back and under the carpet! then you are not messing with the fuse panel. It will be easy to do! I will try to help you as you do it okay!
