Having trouble finding V-LED's
Old 05-27-08, 08:23 AM
D.Jobin
D.Jobin's Avatar
Default Having trouble finding V-LED's
Do the V-LED's that look like these not come in 9005 bulb type anymore? All I can find is 9006...or am I suppose to use the 9006 instead? Help please!
Old 05-27-08, 08:41 AM
Drunkebuda
Drunkebuda's Avatar
where you trying to put these high beam or fogs?
Fogs are 9006 high beams are 9005.
Old 05-27-08, 11:17 AM
D.Jobin
D.Jobin's Avatar
DRL's, so high beams.
Old 05-27-08, 11:46 AM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
No, I couldn't find what you wanted on eBay.
However, I typed "LED" and "9005" on eBay and found one by PIAA. Perhaps that can work?
Old 05-27-08, 11:58 AM
llamaboiz
llamaboiz's Avatar
While PIAA may have... overpriced/overrated
As for 9005's from Vleds, just wait untill they have a new shipment, then it'll pop back up on their website, you just need to keep checking
Old 05-27-08, 12:11 PM
D.Jobin
D.Jobin's Avatar
So no chance of 9006's working? If I remember correctly the only difference between a 9005 bulb and a 9006 bulb was the painted tips, as seen below. Everything else should be the same.
Although, it looks like a little modification would be in order.
Quoted from some BMW site:
"Why using a 9005 bulb: 9005 bulbs are 65W and are not capped at the end, 9006 bulbs are 55W and have a cap at the end. You have to slightly modify the 9005 bulb to fit the 9006 socket. Light increase is from the increase in lumens from the 9005 bulb. A 9005 bulb has 70% more lumens than the 9006 (1700 lumens vs 1000 lumens). HID has 3200 lumens."
Old 05-27-08, 12:21 PM
D.Jobin
D.Jobin's Avatar
Just a thought...if the 9005 is rated at 65w and the 9006 is rated at 55w, could I potentially blow or fry that 9006 bulb by giving it an extra 10w? Now I know the DRL's are the highs ran at low power but what would happen if I say flashed my brights, which would send the full 65w to the bulb?
Old 05-27-08, 12:24 PM
llamaboiz
llamaboiz's Avatar
well if you flash your DRL with LED bulbs... it wont make any difference since LEDs dont run at... more than 3w(?) so no worries.
Old 05-27-08, 02:05 PM
AACstyle
Former Vendor
AACstyle's Avatar
9005 has a different socket and a wider stalk.
Old 05-27-08, 02:31 PM
Monkey250
Monkey250's Avatar
I wouldnt recommend doing the 9005 mod. I did it for my other car and it burned my harness. Just get HID's!
Ken167
08-26-16 12:05 PM
jusdach
03-24-13 09:02 PM
Frosty250
10-10-11 10:03 AM
ns3425
03-25-08 05:45 PM
aznpapaya
07-07-07 09:56 AM
Quick Reply: Having trouble finding V-LED's
