steering wheel tightness 06 vs 08
#46
I have already got the steering damper Swaybars Tein CS and spacers... but the steering is still lighter than a stock 2008... So I it must be something else...
#49
Just installed it, but.... sorry guys, if this is really from an isx50 2008, than this isnt the key of the stiffer steering...
Let me explain my experience after a first testdrive:
- The steering is a little bit more direct/precise than before..
- The steering is a little bit lighter, less strenght needed, so there seems to be a little bit more power assist.
- The steeringfeel is a little bit more smoother, related to directness?
Conclusion for now: The feel is better, but a little bit lighter..
I will let you guys know more when I drive some more with it...
#50
These 2 are the only parts left that are different from 2007 vs 2008:
YOKE SUB-ASSY, STEERING SLIDING W/SHAFT
45206-30110 ALE20, GSE20..LHD (08/2005 - 06/2007)
45206-30111 ALE20, GSE20..LHD (08/2007 - 07/2008)
And
SHAFT ASSY, STEERING INTERMEDIATE, NO.2
45260-30160 GSE20; ALE20..LHD (08/2005 - 06/2007)
45260-30200 GSE20; ALE20..LHD (08/2007 - 07/2008)
And
#54
I went from an '06 to an '08 during the test drive and I noticed a slight difference just driving along normal roads, I didnt notice how tight it was until i was speeding on the freeway. Definately a great improvement if it can be done.
#57
Guys
I Finally installed the Steering ECU of the 2011 Fsport in my 2006.. I can confirm that this is just plug and play without any errors on dash.
The steering ecu seems to be calibrating by itself, so it is getting heavier each time I drive ( this was also like when I put in the 2008 ECU)
I still need to let lexus calibrate the steering ecu, so untill then I can only say that the steering feedback is better en stiffer than it was..
#58
Did you ever figure out if it was worth it to have lexus calibrate the steering ecu?
I have an 06 that I threw a 2008 steering ecu on and I would rather give it time to let it *learn*( than pay lexus to calibrate it.
Or is it worth it to calibrate it?
iKenn
11-16-07 12:17 PM
