OEM HID: are the fog lamps also HID?
Old 05-01-08, 12:31 AM
sammy5001
sammy5001's Avatar
Default OEM HID: are the fog lamps also HID?
My IS350 with Premium package came with the HID headlamps and I'm planning to replace the low beams with 8000k D4S bulbs.
The manual specifies that I can use D4S bulbs for low/high beam but it doesn't say that for the fog lamps. So are my fog lamps HID-ready? Can I stick HID bulbs into my fog lamps and which model should I look for?
Old 05-01-08, 12:36 AM
cliffud
Former Vendor
cliffud's Avatar
sammy- nope. the oem fogs are halogen bulbs. in fact, they're a 9006 bulb type. you can pick up a kit for your fogs for $170 shipped from the link in my signature. here's a 2is with yellow fogs.
http://mobilehid.com/2is.htm
good luck.
c.
Old 05-01-08, 09:51 AM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Arrow
There always this route....
Lexus JDM HID Fogs..
Old 05-01-08, 10:11 AM
Brian231
Brian231's Avatar
That JDM lfog lense looks like a projector housing and that is what I have been looking for. I bet they are quite costly?
Old 05-01-08, 10:20 AM
freqfly
freqfly's Avatar
The OEM fogs are halogen bulbs, you can pick up a conversion kit to convert them to HID's. As far as your low-beams, I would recommend 6000k instead of 8k. You'll start to loose some performance of your bulbs going past 6k. Just my 2 pennies.
Old 05-01-08, 11:29 AM
Joe Z
Joe Z's Avatar
Yes... But very much worth it...
Old 05-01-08, 11:57 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
$1K+
Old 05-01-08, 12:22 PM
Joe Z
Joe Z's Avatar
Originally Posted by kickin8
$1K+
True.. but look at what your getting.. A Complete Factory Plug & Play Kit.. 2 Projector Housings with HID Bulbs & LED Clusters, 2 Ballasts, All required wiring.. All required mounting hardware.. 2 OEM painted Trim bezels...
.. and a full day in the garage with a case of Corona..
Old 05-01-08, 01:30 PM
pisaykotik
pisaykotik's Avatar
$1K+
That and the install cost would be too rich for my blood. I wish it was a little lower.
Old 05-01-08, 02:55 PM
Keith13b
Keith13b's Avatar
Fogs are a DIY job - don't pay someone for that!
Old 05-01-08, 02:59 PM
gocubs08
gocubs08's Avatar
where can I find fog light bulb replacements that look the same color as the stock HID low beams?
Old 05-01-08, 04:47 PM
Drunkebuda
Drunkebuda's Avatar
not this one it requires some moding of the bumper to have it fit and you have to cut away some stuff plus the wiring diagram is in Japanese
Old 05-01-08, 04:49 PM
freqfly
freqfly's Avatar
Where can I buy the kit? Got the $1k, got the Corona, got the garage, just dont got the stuff.
Old 05-01-08, 10:51 PM
pisaykotik
pisaykotik's Avatar
I remember it used to be a lot cheaper than this. Don't know why it's even more expensive now.
Old 05-02-08, 07:53 AM
Joe Z
Joe Z's Avatar
Lightbulb
Yes, there is some cutting involved and this is not reversible...
Once you mod the bumper, you can never go back to the OEM US Spec Fogs.
The wiring is a bit tricky, but not too confusing. 99% plug & play.!
You will need a dremel and lots of patience.. the Corona helps..
Below is the link of the only place I know in the USA that can get them...
http://l-tunedparts.com/product/?id=1995.
^^ ^^ The very weak USD verses the JP Yen is causing a significant increase on many imported products across the spectrum here in the USA.
Joe Z
gs3some
02-11-11 03:35 PM
is250al
11-14-07 03:42 PM
kidluvsole
08-11-07 09:32 AM
Jace7
10-18-06 08:34 PM
omgitsroy
10-11-06 05:54 PM
Quick Reply: OEM HID: are the fog lamps also HID?
