IS350 alternator
I'll research this and get back to you. I'm back at work on Monday to find out the specs on it. I think the GS350 will switch out with ours but I'm not sure of the current output on either car.
-Joe
-Joe
Amps = Watts / Volts
so
X = 2,000 / 12
X = 166.66
I'm not sure what the current output of the IS250/350 alternator is, but I guarantee its not > 160 Amps. In fact, I'd guess it to be between 90-120. And remember that the 166 amp calculated draw is JUST the audio... so figure on another 40 amps or so to run the car. Now you're looking at 200 without any reserve.
That being said, you probably want to run a second set of batteries in the trunk or look to do a custom alternator setup. But I don't have a whole lot of experience with ICE, so maybe with a Cap or two you don't need the extra capacity... i dunno.
Tech Info Resource
The 2008 GS460 alternator is rated at 180A@12 vdc. The stock unit for the IS350 is rated at 150A. Keep in mind, alternators actually put out 14.4 vdc, not 12, so this alternator would be powerful enough to actually produce almost 2.6 kW. The stock unit is enough for 2.2 kW. Not sure if it's a bolt on replacement though. Terminals can be in different positions to accommodate the engine's configuration.
Understand this to be older thread however, was interested in possible alternator upgrade as well, and if the alternator specs would be the same for 2007 GS460 and 2008 GS460, buthave different mounting points etc.;
Part 27060-31060 fits the following vehicles;
2006 - Lexus GS 300
2007 - 2011 Lexus GS 350 (VIN starts with JTHBE / JTHCE )
2007 - Lexus GS 460
2006 - 2013 Lexus IS 250 A/T
2006 - 2012 Lexus IS 250 M/T
2006 - 2013 Lexus IS 350
Part 27060-38060 fits the following vehicles;
2007 - 2011 Lexus GS 460
2008 - 2014 Lexus IS F
2006 - Lexus GS 300
2007 - Lexus GS 460
andper10
05-05-15 04:27 PM
ArmyofOne
Maintenance
11-22-08 03:15 PM
2006, 2706031060, 2nd, 350, adding, alternater, alternator, amps, big, check, is250, is350, lexus, location, upgrade
