nice. i got project kics ones also but i went 10/20
How do you like them? I traded a set of springs for mine, so i didnt have much choice. But i am very happy with them though. Are you using any kind of hubcentric ring up front or any way to center the wheels? I have hub rings in the rear, but nothing up front.
The rear spacers have hubcentric rings, the fronts do not, but i cant seem to find any available to fit these spacers. So i might have to make something There is a very minimal vibration right now at 60mph.. above or below that, its smooth.
I got the same wheel spacer (10mm front and 15mm rear) but I got mine from
ichibausa.com and they are hubcentric. The hubcentric is directly built in to the spacer, one piece machined, but I had to replace the studs with longer ones which came with the package. I got the complete set for $180+ shipped. No vibration baby and I did the install myself.
I am using 15mm all around, I wanted to keep it even looking. I had 20mm in the rear but they were more flush than the front so I swapped. I think 15mm is the maximum you can go with the stock wheels and not have to worry about rubbing.
Thanks everyone! Im pretty happy with the look... ill post new pics when i get the G-Spiders on there. Part of me wishes i had used the 15/20 combo.. but im happy with what i got haha.
H&R has them made for our car. Another member helped me find them. I needed 5mm but i got on the site again and they also have the 10mm. I can send you the link if you would like
