Illuminated Scuff Plate not glowing.. how to fix?
Old 11-21-07, 08:55 AM
Qsmooth
Qsmooth's Avatar
Default Illuminated Scuff Plate not glowing.. how to fix?
Hey guys, New to CL here.. I was wondering how to change the bulb on driver side illuminated scuff plate? Passenger side is fine and glows blue but on the the drivers its not lighting up at all. Any suggestions from you all experienced owners?
Interior lights are on when I open the door. I checked the door contact.
Specs:
Tungsten Pearl
2007 IS250 AWD / NAVI Non ML
Thanks in Advance
Old 11-21-07, 09:28 AM
ReLexin
ReLexin's Avatar
hmm... sounds like a blown bulb in the scuff plate since the other lights work when u open the door. I don't have these cool scuff plates so i can't help. good luck with the fix thou.
And..... Welcome to CLUBLexus!!!!!!
Old 11-21-07, 10:34 AM
ES3
ES3's Avatar
Should be under warranty, let the dealer handle it for free!
Old 11-21-07, 11:38 AM
IS350jet
IS350jet's Avatar
I don't think you can change the bulb in those.
Old 11-21-07, 01:08 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Arrow
No actual bulb to change.
You can test your passenger side plate on the drivers side or vice versa.. to see if its the wiring or something else..
If its drivers side plate is dead, have your local dealer replace under warranty..
Old 11-21-07, 01:36 PM
andone
andone's Avatar
I don't think you can change those and maybe you should check to see if it is wiring problem.
BensonTT
RX - 3rd Gen (2010-2015)
06-19-20 05:15 AM
walabee727
Build Threads
10-29-17 02:58 PM
vj3
03-12-08 07:07 PM
Abear
GS - 1st Gen (1993-1997)
04-03-06 12:12 AM
Quick Reply: Illuminated Scuff Plate not glowing.. how to fix?
