DIY Sport Pedals IS350 IS250 w/ Pictures!
Old 08-20-07, 12:06 AM
istundra
istundra's Avatar
Originally Posted by ben_r_
Nice! Looking good thanks for the write up. Would have been really helpful though to include some more pics of the gas pedal install like removing the pin and so forth. Now that those pedals are a reasonable price I may pick up a set.
Ahh i see. I do not believe punching and resetting the pin is an obstacle.
The major obstacle is removing the accelerator pedal.
For your reference, I have edited the original post with a sample picture of a pin punch tool for the removal and reset of the pin.
As you can see, my post is to be used with conjunction of the OEM Install Manual. I am just adding additional pictures on How-To remove the accelerator pedal.
I have read on CL that some members have taken 2 hours to install these pedals. However, for me, it took 30 minutes or less. It merely boils down to the technical experience of the installer.
Old 12-06-07, 10:53 PM
i3urton
i3urton's Avatar
has any one tried useing a small vise to get the pin out....well ill have my car audio guys do it tomorrow at work..
Old 12-06-07, 11:51 PM
istundra
istundra's Avatar
doubt it. you can try tho.. but you need to knock the pin out.
Old 12-07-07, 07:31 AM
ReLexin
ReLexin's Avatar
I asked Santa for these for x mas. I hope he brings them.
Old 12-09-07, 06:45 PM
i3urton
i3urton's Avatar
=( my car audio guys at work couldn't do it.. so i guess im go buy the angle wrench and try this myself...and the pin is hollow i see..so i need an exact fix to knock the pin out... and if i knock it out a lil bit will i be able to pull it out with pliers???
Old 12-09-07, 06:54 PM
jimmyjazz
jimmyjazz's Avatar
My pin pushed out to the right, the hole is tapered.
Old 12-10-07, 01:29 AM
iialcii
iialcii's Avatar
wow great will keep this thread in mind in the future. when i actually change my pedals but its one of the last things to do on my list.
Old 12-10-07, 11:20 AM
i3urton
i3urton's Avatar
were you able to get the pin out?
Old 12-10-07, 11:26 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I am in the process doing that right now....
Old 12-10-07, 06:29 PM
i3urton
i3urton's Avatar
i did it i feel like i can do anything...thanks tundra for this diy ...would of never been able to do it with out that angle socket wrench...i found out u need a 1/8 punch to get that pin out... if any one needs help in so cal ...hit me up "pm"
Old 12-10-07, 06:54 PM
istundra
istundra's Avatar
no problem. the biggest obstacle is removing the pedal assembly. after that, getting the pin knocked out and reset should be simple IF u have the right tools. glad it worked out for u.
Old 01-06-08, 02:29 PM
tshek
tshek's Avatar
it isn't that hard at all. I might sound harder than you though. I take me less than 30 mins to complete it.
Old 01-06-08, 09:43 PM
javyLSU
2IS OG
javyLSU's Avatar
Thanks for taking the time and effort to contribute this DIY to our community, istundra. Your write-up has been added to the FAQ's for the 2IS.
Javier
Old 01-09-08, 09:41 AM
dodongjuan
dodongjuan's Avatar
Where did you get the allow pedals ..
Old 01-09-08, 09:47 AM
tshek
tshek's Avatar
The pedal that use in this DIY is the OEM one. You can find it from Sewell
They have a GB going on now
https://www.clublexus.com/forums/sho...d.php?t=328137
185 a set.
Quick Reply: DIY Sport Pedals IS350 IS250 w/ Pictures!
