Front Center Vent rattle
Does anyone know how to remove the front windshield vent? I believe this is the cause of the rattling noise coming from the front centre speaker area. When I drive and i hold the vent specially, it stops.
Thanks
Thanks
I have the same problem, I have taken it to the dealer a couple times and have tried myself (half-assed mind you) to fix it but it didn't work. What you need is some fairly thick glue backed felt to put around the edges. All you do to remove it is pop it out from the front (the side closet to you), and pull it up. I used one of those small flathead screwdrivers ad wedge it in and pulled it out. Hope it helps.
hades281
01-23-12 01:16 PM
