Stock 17" to 18", do I need to re-program TPMS?
Hi.
I just bought a set of used 18" OEM wheels for my IS250, since I did not like my 17 inch wheels. Now, I am trying to find out if re-programming the TPMS is needed when I transfer them from my 17 inch wheels to 18 inch ones. I called one tire place and they said that I need to.
Also, are these bridgestone tires that come with 18 inch wheels as stock, all season tires?
Super Moderator
If you transfer your existing sensors from your old 17" wheels to the new 18s, TPMS won't need to be reprogrammed. If you bought the 18" wheels with new sensors, you will need to reprogram TPMS. If the latter, make sure you get the numbers off the new TPMS sensors before you mount tires over them.
Super Moderator
To enter a new set of TPMS sensors, you'll need to visit the dealer, or someone with a factory scan tool -- and you'll need to record the numbers off the TPMS sensors, preferably BEFORE you mount tires over them.
Thanks for your anaswers.
That Sears auto center guy sounded like he knew nothing about what he was talking about.
Anyways, I'm thinking if I should keep these wheels and tires or not, because the tires on the wheels are summer tires, which I just found out. My fault not checking them before buying them. Those tires for the rear wheels are pretty costly...
thrillamac
Wheels and Tires Classifieds
12-19-16 06:27 PM
