Hit A Pothole Last Night
Tech Info Resource
That's actually more common than anything. The outside is very hard to bend, but the inside bends relatively easily.
If the inside rim is bent, wouldn't it throw off the balance? So when you hit high speeds on the freeway, wouldn't you feel the vibrations? At least that's what I experienced on the last wheel I damaged.
Maybe we should start a - Spotted Pothole thread (j/k)
Tech Info Resource
You'd be surprised how far off it can be without knowing it. A 4mm out of round is enough to need straightening, but not enough to make the steering wheel vibrate. AMHIK.
Ok, if the wheel is slightly bent/damaged and you don't feel any vibrations, could there be any long term damage to the car? I guess I can take it off and look at it on a wheel balancing machine. But if there is nothing wrong with the way the car behaves, why bother? Just trying to understand the long term effect, if any.
Flip.. I had the same issue with my OEM rim. It was bent but no one could see any physical damage.
But when the put the rim on a balancer, and through varying speeds they could finally see the issue.
Have you tried driving the car at different speeds? I didn't feel any vibrations until I hit a certain MPH range, and I was told.. by several people that a bent rim can increase wear on your tires, and put stress on your steering system, and something about ball joints. I don't know to what extent but it made me terribly uncomfortable to drive with a bent rim.
I drove on the freeway, no vibrations whatsoever and the car still drives straight. When I got home, I checked the other side of the rim, no damage. This morning, no flat tire and pressure is the same from the last time I checked it . Whew! These Lexion wheels are tougher than I thought. Just to be on the safe side, I will have the car checked.
No vibrations at any speeds and no bubble or visible damage on the tire and rim (both sides). But I can't be sure until it is taken off, looked over with a magnifying glass, and put on a wheel balancer.
I had a 19" OZ 1-pc wheel and had the same experience as you did. No damge to wheel or tire. A coumple months later I hit another pothole much smaller at only city speeds and the rim CRACKED and bent at the same time. I took it to a wheel shop and the manager advised there were some internal damage (small crack) from the first pothole incident, and the second impact (althought much less impact) was severe enough to further open the crack.
good luck.
Just came back from a reputable shop. I didn't take it to the dealer because I don't want to open a can of worms due the mods I made to my car. Anyway, no damage to the wheel and suspension.
muffin57
09-27-06 09:32 AM
