View Poll Results: are you running synthetic or a synthetic blend?
full synthetic
238
59.95%
synthetic blend
19
4.79%
dinosaur oil
39
9.82%
whatever the dealer fills it with
101
25.44%
Voters: 397. You may not vote on this poll
how many are running full sythetic or a synthetic blend?
Old 01-24-07, 09:21 AM
bagwell
bagwell's Avatar
Default how many are running full synthetic or a synthetic blend?
just curious, thanks.
Last edited by bagwell; 01-25-07 at 03:53 PM. Reason: freakin typo in the thread title
Old 01-24-07, 09:23 AM
jsquared
jsquared's Avatar
i switched to mobil1 5w-20 fully synthetic at 10K.
Old 01-24-07, 09:37 AM
gsrthomas
gsrthomas's Avatar
I'm running Castrol 5-30 right now thats because my car only has 800 miles on the odo.
Once my car hits 10-25k miles then I will switch to full synthetic either Mobil 1 or Castrol Synthetic.
Old 01-24-07, 09:51 AM
Bichon
Super Moderator
Bichon's Avatar
Currently running Mobil 1 5W-30. Planning to use Mobil 1 5W-20 at the next change.
Old 01-24-07, 09:58 AM
Gernby
Gernby's Avatar
Same here.
Old 01-24-07, 10:11 AM
G35TOIS350
G35TOIS350's Avatar
valvoline full syn here!
Old 01-24-07, 10:16 AM
t0e
t0e's Avatar
Using Royal Purple 5W-30 synthetic blend....
Old 01-24-07, 10:22 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
5W-20 Mobil 1 in the IS and the Scion. Supra gets 10W-30 Red Line exclusively.
Old 01-24-07, 12:06 PM
javyLSU
2IS OG
javyLSU's Avatar
Mobil 1 5W-20.
Javier
Old 01-24-07, 12:42 PM
Lupin5
Lupin5's Avatar
I'm running Mobil 1 5W-30. Changed it at the 10,000 mark. Next oil change coming up in the next 2500. Any benefits for 5W-20?
Old 01-24-07, 12:51 PM
tcho82
tcho82's Avatar
If you change your oil often enough, I've found there really isn't any need to go synthetic. I ran normal dino oil in my S2000 for years and never had any problems. Plus unless you are going to track the car, the oil will never be really abused to the point where the synthetic protection would be worthwhile.
Old 01-24-07, 12:59 PM
Gernby
Gernby's Avatar
If I remember correctly, 5W-20 is the new recommendation from Lexus.
Old 01-24-07, 01:02 PM
syn1313
syn1313's Avatar
My oil cap says 5w30 not 5w20.. Mobil Full Syn
Old 01-24-07, 01:07 PM
IS_Mine
IS_Mine's Avatar
The new recommendation is 5w-20.
Lexus corp. released it.. and someone posted it, anyhow.. I just recently talked to my service tech to get oil filter number and oil to be used and he said 6.7 quarts of 5w-20.
Old 01-24-07, 01:10 PM
Bichon
Super Moderator
Bichon's Avatar
That's because the recommendation was changed after your car was manufactured. See Lexus TSB EG006-06. 5W-20 is now factory fill and recommended for best fuel economy and cold starting performance. 5W-30 is also a perfectly acceptable oil, and it's what many dealers are still using.
Quick Reply: how many are running full sythetic or a synthetic blend?
