Is Japanese ECU configured for 97 octane?
I'm thinking of getting the TOM's supercharger for the 350, but since it comes with a remapped ECU, is it based on Japanese 97 octane gas?
Tech Info Resource
Tech Info Resource
^^correct. They use research, we use (research+motor)/2. Premium fuel around the globe is within a point or two unless it is race gas. Same is true in Europe. Big numbers, generally the same performance as here. There is a LOT to this subject though.
Tech Info Resource
Agreed. The point is, if you import a Japanese model kit, you will not be able to plug in the ECM and have it work.
Plus, wouldn't cutting and splicing work? Works with regular engine managements. Any engine management systems in the works? I'm still trying to figure out how to install one, but the 350s injector arrangement scares me (or just because I don't know much about it).
I was assuming it would be more of a cost saving benefit for Toyota to use an ECU with enough I/O for all configurations and flash it for each application.
Tech Info Resource
None of the above. Toyota use different technologies for different requirements. Japan generally uses MAP for fuel management, but US emissions requirements are easier to meet with MAF. Completely different software approaches to cracking the same egg. They are completely incompatible, and often have differing pinouts and wiring harnesses.
I haven't 100% confirmed this is the case, but I know it has been in the past with other models. I have been told the ECMs do not interchange, so swapping them will not work.
I have seen Toyota do this with both electronics and mechanics. If you've ever tried to put J-spec turbos on a USDM Supra, you know exactly what I mean.
