Headlight Adjustment Success!
#121
A couple comments: first, I tried the 10mm socket method in the rear of the car which was supposed to be really easy and works great. It is actually more trouble than the proper method, and made only a very tiny difference.
The screwdriver under the hood is really easy and works unbelieveably well. Do what the owners manual and the PDF says, and adjust both screws on each side. Turn your screwdriver COUNTERCLOCKWISE which turns the adjustment bolt clockwise and raises the headlights. Remember to do both adjustments on each side. You'll need an 8" philips screwdriver and a little "feel" and faith because you can't see into the hole to turn the hidden adjustment screw. But you'll feel it turning.
I turned the adjustment gear 2 full turns on each side (which is 10 turns of the screwdriver) and it made a very noticeable difference. Good luck.
#124
OK, because I love you guys so much I went downstairs and took apart the engine covers and took pictures... Here we go...
Picture of the engine with all covers on:
Picture of the engine with all covers off:
Picture of the Driver's side headlight screw location:
Closeup of the Driver's side headlight screw:
Picture of the Passenger's side headlight screw location:
Closeup of the Passenger's side headlight screw:
Another closeup of the Passenger's side headlight screw with the arrow showing how the screwdriver should be inserted and the adjustment screw with a circle around it:
And of course, all of this is on my website as well...
Hope this helps!
Hope this helps!
sorry to ask this but i'm driving a 06 - is250 right hand drive and the placement of the 2 adjustments nuts are found but may i ask how do i locate the other 2 adjustment parts?
Is there any possible way that you take a picture of all the placement of all 4 adjustment nuts?
i have tried to read from the pdf but i still cant find the one that is for horizontal adjustments. btw, i have lost my owner manual.
i am new in adjusting such things. Sorry once again to ask for the help from all of you guys.
#126
yes i do have HID with AFS as mine was luxury package with ML sound system. i did lowered my car before but it was all done by the car shop.
btw, i have noticed that only my left side headlights will move when my car is started whereas my right side stays stagnant. How do i resolve this?
I NEED HELP PLEASE!!
#127
does the car have to be on for the adjustment to work?
also i have a LS460 does this adjustment work on my car as well? turn counter clockwise to raise the headlights?
#130
I tried adjusting My HID's leveling sensor and I got the HID to point super high and far lol it actually works really great except what I wonder s am I high beaming people now? lol maybe I should switch it back
#133
After replacing a water damaged headlight assembly on my 2007 IS250 with HID and AFS - I needed to adjust the lamp. I read posts on this forum and others but really wasn't sure what those bolts were doing. So, at my peril, I dremeled into my old headlight assembly so I could see how it worked.
Original post is here:
https://www.clublexus.com/forums/is-...ml#post8714814
