This Forum is Sponsored By:
01-27-07, 10:17 AM
Dabigman - Can you tell me the reason to change out the LED flasher?
Is that for the lights inside or outside?? Im lost...
01-27-07, 01:38 PM
they're for the lights outside... your signal lights.
__________________
06 SGM/Black IS250 - Manual/Lux/Nav
"Enjoy the Ride"
01-28-07, 09:59 PM
hey dabigman, after changing out the flasher module, does your signal lights still flash when you lock/unlock your car? i just got around to changing out the flasher module and noticed my signals.. both the incandescent front signals and led rear signals don't flash anymore when i lock/unlock the car.
__________________
"Enjoy the Ride"
01-29-07, 01:09 AM
Quote:
Originally Posted by
ULTiMaX99
The light will not flash after the mod. I changed the front/rear turn signals to LED. Check out my post on headlight removal.
http://www.clublexus.com/forums/is-second-generation/261379-headlight-turn-signal-removal-dyi-pics.html
__________________
Humans make Music,
Music makes Miracles.
~Dj_AmTraX~
01-29-07, 01:27 AM
doh that sucks then. i wish i had known that i'd lose the flashing signals when i lock/unlock the car. guess its back to stock...
__________________
"Enjoy the Ride"
01-29-07, 07:36 AM
Would all of this apply to the rear turn signals as well?
I still think its strange that Lexus gave us LED brake lights, but not LED turn signals...
01-29-07, 01:57 PM
If you change the flasher, the lights will no longer flash when you arm/disarm the alarm.
__________________
Humans make Music,
~Dj_AmTraX~
11-15-08, 12:41 AM
Just turn on your flashers, get under your dash, reach your hand up there and you'll find it. You can feel it clicking. The flasher from V-LEDS.com works perfectly, but you do lose the lock unlock confirmation blinks.
11-15-08, 12:44 AM
The front takes two 7440 amber bulbs on each side so 4 total. You need an bulb with radial firing LEDS because the sit vertically in the housing. Also you need to take off the front bumper to get to them, also you don't have to but it makes it easier to remove the drivers side headlight, there is one that is a real bugger to get at.
04-08-09, 03:22 PM
I did it here. Flasher doesn't hyper flash, but killed my stock alarm arm/disarm flashes.
http://www.clublexus.com/forums/is-s...-dyi-pics.html
__________________
Humans make Music,
~Dj_AmTraX~
04-08-09, 04:07 PM
Dj_AmtraX
I can't believe it took that much work to change turn signal lights... if mine blow out, i'm just selling the car. less effort that way
__________________
2006 IS250
XenonDepot 4300k
04-08-09, 09:23 PM
2006 Lexus IS
DaBigMan,
Do your lights flash to confirm that you lock or unlock your doors? Btw, the front headlight removal isn't too bad. Can be done in about 1 to 2 hours.
__________________
06 IS250 Crystal White
EXT: | Tom's rear | Ings+1 Sides | Jun Roof Spoiler | Jun Trunk Spoiler | 5Axis Front Lip | FX35-R HID Projector Retrofit 6k HID Fogs | 6k HID Driving | LX-Mode Grilles | JDM Mirrors | 360 V-LED |
PERF: |Tanabe Medalion Touring | F -Sport Lowering Springs | F -Sport Rear Sway Bar | Volk GT-C 19x8.5 19x9.5 |
ICE: | Front and Rear Infinity Kappa 60.7 CS | Infinity Basslink 2 |
04-09-09, 07:28 AM
2007 Lexus IS
the reverse lights won't have any problems as it is a consistent voltage
__________________
2007 Lexus IS250 Gone but not forgotten
10-15-09, 10:37 AM
Anyone found a flasher that will also fix the alarm on/off confirmation blinks? The flasher I am using fixed hyper flash but killed alarm blinks.
__________________
Humans make Music,
~Dj_AmTraX~
Tags
8198002030 , 8198050020 , 8198050030 , 91 , corolla , denso , flasher , flashers , gx470 , harness , led , lexus , located , location , number , part
Display Modes
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
