This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Thread Tools Display Modes
Old 12-12-06, 05:51 AM   #1
Technique
Trader Score: (0)
Technique's Avatar
Quote:
Originally Posted by ecalica428 View Post
wilol a version 4.2 will work or only ver 5.1?
Only V5.1.......
__________________
'07 IS350 Black Sapphire/Black (Sport/Nav/ML/PA/HW/Z1/Front Spoiler GFX)
Nav Hack w/ Destination Entry While Moving Switch | DRL's off | Seatbelt Buzzer Off | HW Mod
# of visits to dealer since pickup: 2
My IS350 Experience Webpage
Technique is offline   Reply With Quote
Old 12-19-06, 09:02 PM   #2
istundra
Trader Score: (0)
THank you technique. you are alot of help.
I inserted the hybrid disc I have made ~_^ and it does not read.
It says "Unable to Read Map Disc"
so i pressed eject and tried again. Nothing happen.
DId you remember seeing this in your 07?
istundra is offline   Reply With Quote
Old 12-19-06, 09:08 PM   #3
Technique
Trader Score: (0)
Technique's Avatar
You need to pull the fuse for the navigation unit. The one marked "TV". This will force the re-load of the older firmware... Try that...
__________________
Old 12-19-06, 09:40 PM   #4
sickntired
Trader Score: (0)
istundra:
be sure you burn the disc using ISO 9660 format. Don't burn it using UDF as it won't read that type of disc.
Use imgburn (do a google search for it) to create an iso image which you then burn.
This worked for me.
__________________
Mine: 2008 GX 470, Nautical Blue, Sport Package w/KDSS, Nav, Mark Levinson, RSES
Wife's: 2004 RX 330, Millenium Silver, black interior, Nav, Mark Levinson, RSES, Gen 3 to Gen 4 Nav upgrade
sickntired is offline   Reply With Quote
Old 12-20-06, 01:56 AM   #5
istundra
Trader Score: (0)
I also used some 3M double sided tape to help me remove the clock panel.
I taped the 3M tape on the clock panel and the other end on something flat.
Once i inserted the clock removal tool... I pulled the piece with the tape stuck onto it... and it came out fine.
do not use a pry tool.. u will scratch the clock panel.
Old 12-20-06, 02:43 AM   #6
lobuxracer
Tech Info Resource
2005 Scion tC
My Garage
Trader Score: (0)
lobuxracer's Avatar
Send a message via Skype™ to lobuxracer
Pics can help understand.
__________________
'08 USE20L−FEZRHA Obsidian
'93 JZA80L-ALFVZA Alpine Silver
Most performance mods need a watch and timed course to demonstrate actual improvement. Few deliver the advertised claims. Many are actually worse than stock. The best performance mods are made to the driver.
Emotional arguments - They're not just for chicks anymore.
lobuxracer is offline   Reply With Quote
Old 12-22-06, 09:47 AM   #7
tazdevl
Trader Score: (0)
Seems that this is not exactly a fix. Some functionality enhancements require a firmware update. If you use the 05 series load file, you aren't going to be able to benefit from some of the fixes. This just allows you to use the map data and maintain the software bypasses.
__________________
2010 RX 350 AWD Tungsten Pearl/Black - Luxury, Comfort, Nav, Levinson, HUD, Enform, Parking Assist, Tow, Remote Start.
tazdevl is offline   Reply With Quote
Old 12-22-06, 10:07 AM   #8
lobuxracer
Tech Info Resource
2005 Scion tC
My Garage
Trader Score: (0)
lobuxracer's Avatar
To what fixes and functionality enhancements are you specifically referring?
__________________
Old 12-22-06, 10:47 AM   #9
Bichon
Trader Score: (0)
Bichon's Avatar
Quote:
I'm assuming he is referring to the fixes in TSB EL013-06. With the new load file, I'm able to see and lock about double the number of satellites at any given time.
__________________
2006 IS350, Crystal White/Black, LT, NV, PA, HW, Z1
Bichon is offline   Reply With Quote
Old 12-22-06, 12:02 PM   #10
ES3
2008 Lexus IS-F
Trader Score: (0)
ES3's Avatar
Quote:
So are you saying we may gain the override while moving feature but definitely lose the gps accuracy?
ES3 is offline   Reply With Quote
Old 12-22-06, 01:00 PM   #11
Bichon
Trader Score: (0)
Bichon's Avatar
Quote:
Even worse, I was having episodes where the number of usable satellites dropped below four, turning off the GPS indicator on the screen. If it stayed in that state for long enough, the system would eventually become completely confused, showing me driving through cornfields or even out into the ocean.
Before switching to the old version of the software, read the early posts in this thread: http://www.clublexus.com/forums/is-second-generation/230294-gps-positioning-problem.html to see the kind of problems that some users of the older software were having. For some reason, never definitively determined (heat problem? atmospheric conditions?), most of us with the problem had the most trouble during the hot summer months.
__________________
Old 12-22-06, 01:11 PM   #12
vasco
Trader Score: (0)
Here's one: HVAC ventilate/recirculate/auto setting now persists after turning off the car.
__________________
Vasco
2006 IS 350
Blue Onyx/Cashmere
Sport Package w/ NAV
Rear Spoiler
XM Satellite Radio
vasco is offline   Reply With Quote
Old 12-22-06, 01:21 PM   #13
tazdevl
Trader Score: (0)
I haven't seen the version history but I'm sure there are some bluetooth and phone compatibility fixes, maybe some additional voice commands etc... included as well. Some of these fixes would not make it in with the method described because you need the 06.1 loader.
Maybe a better way of confirming is to see if anyone that has the 05.1 loader with the 06.1 disc has the autorecirc fix functioning. If it isn't, there is a clear indication that the workaround just enables you to use newer map data and maintain the shortcuts.
I'm not trying to minimize anyones work so far, we all appreciate it, but I think the benefits need to be further explored/explained.
__________________
Old 12-22-06, 02:29 PM   #14
Technique
Trader Score: (0)
Technique's Avatar
As with all firmware fixes, if you aren't experiencing any problems, don't worry about it...
There are 100s of people on this forum with 2006 ISx50s, who have the V5.1 disc and have ZERO problems... Using this method is just like having a 2006 ISx50, no difference...
If you are having problems, then use the newer firmware and lose the override...
Or, do what I did and install an override switch + the newer firmware...
__________________
Old 12-22-06, 03:17 PM   #15
Bichon
Trader Score: (0)
Bichon's Avatar
My colleague at work thought he was having zero problems with the nav in his '06 IS. But when we went out to his car in the parking lot, I showed him that the GPS indicator under the map scale was MIA. He didn't realize his car was navigating by gyros and the speed sensor.
I'm convinced that a sizable fraction of the people with the old software who think they aren't having a problem aren't aware that they are having GPS problems because the dead reckoning function that acts as a 'back up' for the GPS is covering up the problem.
__________________
Tags
2007, avn7000, computer, driving, dvd, eject, firmware, gps, lexus, ls430, map, navigation, override, prius, workaround
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
