Sirius/Ipod aftermarket integration
Old 07-13-06, 03:19 PM
TopContndr
TopContndr's Avatar
Default Sirius/Ipod aftermarket integration
Since Lexus is taking forever getting out the fix for Sirius, and we don't have the ability to integrate an Ipod I was wondering if there is an aftermarket company that does this? VAIS Technology has the IPOD integration bit, but I want something that does both. Plus would it be possible to use the XM attenna with this unit?
Old 07-13-06, 05:15 PM
wldweasel0
wldweasel0's Avatar
Not that I have seen. I have been cruising the net looking for iPod integration and nav hacks for the 2IS and all I've found so far is the VAIS SLI unit for true iPod hookup.
VAIS does have an XM kit.
http://www.vaistech.com/slx.html
I wonder if you could get them both, then maybe hookup some sort of toggle button to switch between them. It may be your only option for now.
**EDIT**
I think this is what you are looking for. Sounds like VAIS should have a unit out soon that should do both.
http://www.vaistech.com/forums/showthread.php?t=10
Old 07-13-06, 09:17 PM
rys
rys's Avatar
Apparently Vaistech says that two units can be connected at the same time. I would probably contact them directly and find out if you could do this.
-Brian
stevil
01-03-12 10:25 AM
sbrown02
11-25-06 01:18 PM
Quick Reply: Sirius/Ipod aftermarket integration
