Back Seat removal?
Back Seat removal?
I am trying to route a Satelite antenna cable from my trunk through to the backseat and then to the front dash. Does anyone know how to remove the back seats in an IS350? I know there is an access hole but i don't want to run a wire through there, there is no way to keep it from getting in the way of passengers in the back.
Thanks!
Thanks!
first you have to remove the bottom cushions on the car. you can do that by grabbing the front edge of teh rear seats and lifting up, they are held on by some clips. then you carefully slide the bottom cushion out and remove it from teh car. it is kind of like a hook so you have to remove it accordingly. Then there are 8 screws on teh rear deck where the bottom cushion was. remove those and lift up to remove the rear padding.
Thanks for the reply!
So you simply pull straight up? I know on older cars I have had you push down and then back to unhook the front part of the lower back seat... Have you successfully done this on an IS?
Thanks Again!
Thanks Again!
