Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
Backup Camera
Thread Tools Search this Thread Display Modes
Old 05-14-07, 12:58 AM   #61
discodeca
Trader Score: (0)
RamshakleZ, anyway you can post some pics of the relay, wires, etc. before reassembling everything back? Thanks.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
discodeca is offline   Reply With Quote
Old 05-14-07, 05:32 AM   #62
geoffers
Trader Score: (0)
You don't need the other side of the relay. You could of put the other side of the switch to pin 3 instead of pin 6, but I wasn't sure how far you had gone based on the diagram.
I just thought it was easier to say forget the wires to the LED.
Sorry, didn't mean to sound condescending or anything.
Quote:
Originally Posted by RamshakleZ View Post
I see - I thought I read somewhere above that if you aren't using the LED you'll only use "one side of the relay". But, I must have misinterpreted that. So, the orange wire will still go to BOTH Relay pin 5 and Relay pin 6. Pin 6 will also have one side of the switch. Pin 8 will be to the white w/ black stripe.
geoffers is offline   Reply With Quote
Old 05-14-07, 08:26 AM   #63
RamshakleZ
Trader Score: (0)
Ha, no worries... didn't think you were condescending. I haven't started yet bc I wanted to make 100% certain of what I was doing.
I'm going to wire things as follows:
1. Cut the blue wire.
2. Relay Pin 1 = blue wire from loom
3. Relay Pin 5 = blue wire from Nav unit
4. Relay Pin 3 = tapped orange wire & one side of the switch
5. Relay pin 7 = other side of the switch
6. Relay pin 8 = ground (from whatever source)
Sorry, I'm really good at actually implementing this stuff if I have a very detailed DIY... I just suck at figuring the steps out myself.
__________________
'07 IS350 | SGM/Black | Nav | Premium Pkg | Spoiler | 18" OEM Wheels | HIDs | 25% Ceramic Tint
RamshakleZ is offline   Reply With Quote
Old 05-14-07, 09:55 AM   #64
Lexellent
Trader Score: (0)
Default Corrections
When I received your original post and PM you had described the wire assignments incorrectly with the blue and orange wires being reversed. It appears that this is corrected now. To do this modification without the LED, a SPDT relay would be fine since the second arm is only used for the LED. It was noted in the thread that you could also tap the pin 3 connection for one side of the switch and the other side to the relay coil (here it is pin 7 on this DPDT relay). Another easy way to find the ground is to just loosen a screw on the head unit chasis and attach the ground wire there. This would keep you from having to cut or tap into another factory wire.
Good luck. It seems that you are on the right track.
Lexellent is offline   Reply With Quote
Old 05-14-07, 10:20 AM   #65
RamshakleZ
Trader Score: (0)
Quote:
Did it as I described in my last post and it works like a charm. Thanks.
__________________
Old 05-17-07, 12:49 AM   #66
discodeca
Trader Score: (0)
Has anyone else got this to work, too?
Old 05-22-07, 12:56 AM   #67
discodeca
Trader Score: (0)
Come on, there's got to be someone who's gotten this to work? Anyone???
Old 05-22-07, 07:35 AM   #68
chaos6458
Trader Score: (1)
chaos6458's Avatar
I'm curious as well...
__________________
2007 Lexus IS250 RWD
Glacier Frost Mica w. Black Leather
NAV / G-spider 18 / Rear Lip Spoiler
illuminated scuff plates / Sport Pedals
All Weather Floor Mats including Trunk
Japanese interior hanger / Red Out
Hüper Optik Ceramic Tint 40% / 50%
chaos6458 is offline   Reply With Quote
Old 05-26-07, 07:24 AM   #69
Lexellent
Trader Score: (0)
Default Do you have a specific concern?
Quote:
Since drawing and posting the schematic for this modification I have received a number of PM's about it. Everyone has been able to get it to work as described. The single biggest problem has been an occasional mis-read of the diagram. Once that was resolved it work perfect.
Therefore, I wonder if you have a specific question or concern I can help you with in order that you will feel confident in this modification.
Old 05-26-07, 10:24 AM   #70
Nicelex13
Trader Score: (0)
it works no problem
Nicelex13 is offline   Reply With Quote
Old 05-26-07, 02:20 PM   #71
geoffers
Trader Score: (0)
Works great.
.....And mine is a UK 07 model!! If anything was going to be different, I would have imagined it would be this.
Old 05-28-07, 10:51 PM   #72
bill_und
Trader Score: (0)
Default Simple, but will it work?
Hey all,
I am really interested in doing this mod for my rx400h. I would love to have the ability to turn the backup camera on at will. I am not all that great at wiring, but I am ok. My main question is, couldn’t I run a wire from a toggle switch to the blue wire (soldering the blue wire and the wire from the switch together), with a 12v supply (probably from a cigarette lighter) running to the switch? The idea being that when the switch is on the camera will come on as a result of the 12v power going to the blue wire. The camera will still work when the vehicle goes into reverse because the blue wire is soldered together along with the switch wire. I loaded a crude picture of what I am talking about. Will this work? Any thoughts?
Thanks,
Bill
bill_und is offline   Reply With Quote
Old 05-29-07, 06:40 AM   #73
geoffers
Trader Score: (0)
I'm afraid not Bill.
When you switch across the switch, it will short the positive and negative and blow your boots off.
It is also a good idea to break into the blue wire rather than connect to it as you would be feeding the 12v back into the system, not just the screen to switch into the camera mode.
What you need to do is apply 12v to the blue wire at the screen but stop it going back into the vehicle wiring. You need a changeover switch at least to do this. It has 3 points on. One is common to the other two, depending which way it is switched.
Switch in one way, it is as normal Lex wired. The other way applies 12v the blue wire on the screen side, but disconnects the blue within the rest of the vehicle wiring.
You could pick up the 12v from the cig lighter, but as others have pointed out, the orange which is already at the back of the unit has a 12v supply anyway - just tap off this.
Just using a switch:
Click the image to open in full size.
Old 05-29-07, 10:33 AM   #74
bill_und
Trader Score: (0)
geooffers,
Thank you so much for the post. So the key to a simple switch mod is using a SPDT switch (http://en.wikipedia.org/wiki/Switch). Would a switch like this work?
http://www.radioshack.com/product/in...tId=2062511&cp
And the idea is that with the three connections on the switch the diagram would look like this?
Old 05-29-07, 12:09 PM   #75
geoffers
Trader Score: (0)
Yep - spot on Bill.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Aftermarket backup camera came with car SteveMason CT 200h Model 1 12-01-14 12:59 PM
Backup Camera Question (2011) Surovich RX - Third Generation 7 04-05-14 08:35 PM
Anyone have a 2010 SC 430 with backup camera? Solman SC 430 2 03-13-14 04:15 PM
HD backup camera replacement configt IS - Second Generation 2 11-18-12 01:37 PM
blacked out tailights YooNiBaLL IS - Second Generation 35 04-12-09 04:42 AM
Tags
back, backup, camera, cameras, control, enable, gx470, hack, hacking, is350, lexus, mod, override, reverse, rewire
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
