SmartKey - Did you know...
Old 11-15-06, 01:25 PM
  #46
AntLexus
AntLexus's Avatar
i dont believe there is a way to roll up the windows from the key remote...i think its for safety reasons...
Old 11-15-06, 02:00 PM
  #47
pocky
mooncake master
pocky's Avatar
You can't roll up the windows via the remote in the U.S. models. In every other country you can though.
Old 11-15-06, 02:20 PM
  #48
EBMCS03
EBMCS03's Avatar
Ya I know we cant using the remote... but what would have been nice is to be able to use the door handle lock button since we have comfort access.
Old 11-15-06, 07:04 PM
  #49
Nextourer
Nextourer's Avatar
Originally Posted by RaysIS350
With the SmartKey on you, one simply has to come up and touch the inside of the door handle for the Driver door to unlock. I usually am doing this, just as I'm pulling the door handle open. But you don't have to pull the door handle for it to unlock. Just touch the back of the door handle.
Also:
The default is to only unlock the Driver door, but usually I'm with other people and I'd like all the doors to unlock without me having to grab the remote and hit unlock while walking up to the car. So you can program it to do this.
Simply walk up to your driver door, and hold the LOCK / UNLOCK buttons down together (on the SmartKey until the Car beeps, now if you lock it, walk away, come back and touch the door handle, ALL doors will unlock.
Many would chose only to have the Driver Door unlock, but it's nice to know that you have options.
Here's another thing you might not know.
You've discovered you don't have to pull the handle to unlock, just grab it.
Did you know you don't even have to touch it? Just slide your hand between the handle and the door and it'll unlock.
Old 11-15-06, 07:06 PM
  #50
hapaboy
hapaboy's Avatar
darnit! no japanese service delivery. then i could have gotten my car to japan spec and roll up my windows with a push of a button.
Old 12-18-06, 08:47 PM
  #51
albatross8
albatross8's Avatar
Originally Posted by EBMCS03
UK... only in Europe. Same with BMW and other cars... The sue happy US doesnt allow it. They should have added what Merc uses... a IR port on the door handle so you can roll up the windows only if you are in the line of sight of the IR port.
It shouldn't matter since the windows stop automatically if they detect an obstacle. What's next, garage doors that won't close remotely?
Old 12-19-06, 06:52 PM
  #52
crispy136
crispy136's Avatar
Originally Posted by powders2k
Just what I wanted man........
Thanks!!!!!
Have you found anyway to close all the windows by the remote?????
I would love to have that option....
Since you can open them by holding down a button...You should also be able to close them...
Joe
Not only can you use the remote to close the windows on Australian spec cars, you can also hold in the lock button on the door handle to close the windows.
Old 12-19-06, 09:03 PM
  #53
Irishman06
Irishman06's Avatar
This probably means there's some way to toggle it into doing that. There's no way Toyota would build two different control modules, and install one in US-spec and one in world-spec.
Old 12-19-06, 09:27 PM
  #54
tbs2
tbs2's Avatar
I figured those out since I got mine. But thanks dude
Old 12-19-06, 09:37 PM
  #55
Bichon
Super Moderator
Bichon's Avatar
Could be the same control module with different software flashed into the controller, though more likely an option settable with the factory scan tool.
Old 12-19-06, 09:47 PM
  #56
Irishman06
Irishman06's Avatar
The same control module with a different flash BIOS/ROM/whatever is still a different part, since Toyota wouldn't flash it after its in the vehicle. Which means its something someone somewhere can change...Javy, I looked on TIS, albeit for a limited time since I was at work and lots of execs walk by my cubicle...can you take a look? I found a listing somewhere of all the things a scan tool can set.
Old 12-19-06, 10:06 PM
  #57
javyLSU
2IS OG
javyLSU's Avatar
Do you remember roughly which section it was in? I hate the TIS search tool...
Javier
Old 12-19-06, 10:12 PM
  #58
Irishman06
Irishman06's Avatar
Yea, I wanna say it was in one of the early sections of the repair manual, otherwise it was something totally obvious under another reference...
Old 12-19-06, 10:48 PM
  #59
Hip_hop77
Hip_hop77's Avatar
this thread has already been discussed..
check the tips thread.
Old 12-20-06, 12:53 AM
  #60
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Personalisation Options for US models. We have the functionality, it just isn't linked to the wireless remote.
Quick Reply: SmartKey - Did you know...
