I then ran the wire through the headliner down the OUTSIDE of the a-pillar then popped out the side panel and ran the rest of the wire down there, and voila!
BTW if you installed the ADD-A-CIRCUIT wrong just turn off the car and turn it around make sure you didnt put back all the panels before making sure it works! Enjoy!!!
Hi Isxuel with the add fuse thing that you used, the stock fuse won't fit, because the stock fuse pin so short, so I have to use different fuse type to able put in the add fuse circuit, and what fuse rate do you put in the slot B?, or you leave it? thanks
I have the direct wire kit from valentine one and I am not sure what to do with the red wire with the blue connector. I have already wired the car down into the fuse box area but I am not sure what to do from this point on...
Can anyone guide me as to what I have to do with the red wire in the fusebox?
Well I just got a V1 and a Joy Country Craft mount (super Z 3/4"). Thanks to this DIY I was able to hardwire the V1 directly into the mirror for a clean install. Here are a couple of pics...
