Installing Aftermarket Subs & Amp....NEED HELP!
I just installed my aftermarket subs and amp yesterday following both cmusics ands Tim817's instructions, but i have two problems:
1) The remote wire i connected to does not work. The power on the amp stays on at all times. It does not turn off when i turn off the car. According to Tim817, he connected to the red wire at the very end of the amp. I assumed it was the red one at the end toward the front of the car not the back of the car. Is that correct?
2) Everytime i would open and close the right side doors, the subs would make a "thump" noise. Also, when i open and close the side compartment thing on the front passenger side door, the subs would make a "thump noise." Any idea why this happens?
Also, where are the subs wires located on the amp?....i know they are sky blue (-) and pink (+), but which ones are they on the amp?
Thanks
Thanks
Thanks
Thanks
2. There's an "Auto turn on switch" . Set it to OFF will solve that problem.
If you couldn't find it at the amp location, then try at the subwoofer location like I did.
Originally Posted by tim817
1. it was the red one at the end toward the back of the car.
I removed the rear seats ( the bottom and the back), but i couldnt figure out how to pop up the rear deck to get acces to the sub. How did u get access to the factory sub to tap on to the wires?
I dont have an "Auto turn on switch" on my amp.
I dunno how it worked for you, but i got no power from it.
Originally Posted by mofogasm
i used the red wire which is connected to the last connecter plugged into the stock amp for my remote wire.
However, now i got another problem. Now the subs dont work. For some reason the subs aren't getting any signal anymore. Im getting power to the amp now but the subs arent bumpin.
So then i connected my remote wire back to the original wire that i had before that had continuous power no matter if the car was on or off...and the subs were working again.
That wire may or may not work. It only has 5V when I tested it. If your amp requires a 12V signal then it will not work. I used the orange wire in the 2nd connector with the smaller wires.
aporozco
10-14-10 11:31 PM
VIPnsanity
12-17-09 12:10 PM
